Latest: sparrowdclxvi
Overall: 17139
Online Now [71]:
Visitors: 70
Today: 1802
Total: 113277385
Forums › The Car › 206 Problems › Electrical problem P206 gti
Peugeot_205
PostPosted: Sun Jun 09, 2013 11:09 am Up
hello...I'm a new member here...I have recently bought a crashed 206 gti 136hp...now I am trying to adjust them...but now I ran into a problem...in the crash the car remained without the main jack of the engine installation...now I need the wiring diagram because there are mani wires of the same color...and I don't have any idea how to find the right wires...because on the main jack of the car installation the colours are different...thanks...and sorry for my bad english Embarassed
Peugeot lover Very Happy
PostPosted: Sun Jun 09, 2013 12:44 pm Up
Cable colour wont make a difference, you need to check the wiring codes stamped along each wire.
Peugeot_205
PostPosted: Sun Jun 09, 2013 1:36 pm Up
yes...but I need this codes...because on the car installation...and on the engine installation the codes are different...or not?
Peugeot_205
PostPosted: Mon Jun 10, 2013 6:23 am Up
anyone? Sad
PostPosted: Mon Jun 10, 2013 8:18 am Up
I can sort you out with the Haynes wiring diagrams. Will need to know if the car is pre plex or plexed first.
Peugeot_205
PostPosted: Mon Jun 10, 2013 10:09 am Up
in other words? what's the meaning of "pre plex or plexed first"?
edit: if the year can help you...the car was built in 2000. the model is GTI...100kw...
Peugeot_205
PostPosted: Mon Jun 10, 2013 2:15 pm Up
with the term "installation" I meant wiring loom...nobody has a photo of the wires and their positions on the main connector?
PostPosted: Mon Jun 10, 2013 6:23 pm Up
Re-loom job.
Scrapyard is your best bet on this I think.
And don't use spray on the ECU connectors.
Peugeot_205
PostPosted: Tue Jun 11, 2013 2:12 am Up
I wanted to do it myself...without spending money...
Lecktorious
PostPosted: Tue Jun 11, 2013 3:53 am Up
Trade Rating: +59
Peugeot should be able to supply a wiring diagram for your specific build of 206 if you ask them nicely.
'98 Nile Blue 306 GTi 6
Peugeot_205
PostPosted: Tue Jun 11, 2013 4:50 am Up
did you mean the local peugeot services or on the internet?
