Online Now [419]:
Visitors: 419
Today: 8382
Total: 143317381
Forums › The Car › 206 Problems › ABS HELP
ABS HELP
DREWDEN
PostPosted: Fri Mar 22, 2013 9:19 am Up
Hi All
Just had car in garage to change both outer end cv joints, has from previous
post abs rings kaput. Also had both lower arms, track rod ends, drop arm links done while he was at it to save expense later on. Troube is when i collected car, he said he took car for a short spin round the block and abs light didn't go off, which he said is unusual. would a higher speed thrashing on motorway clear the fault, was going to do it today before i posted, but winters here again.
Just to add sensors ok i think, as the old rings would move now and again and knock the abs off and on at times, with a noticeable change in the brakes.
Any comments much appreciated, until i can give it a thrashing Smile
206 2ltr Hdi glx 53 plate
Big_Rich180
PostPosted: Fri Mar 22, 2013 9:28 am Up
The ABS light should go out within a few mins (if that) of driving.
Something is still wrong.
PostPosted: Fri Mar 22, 2013 9:47 am Up
Well the ABS ECU is have to be cleared,and to do so,you need to do a code reading,and clear it,and if it stays on,then something is still wrong definitely,only the Airbag light goes off by itself if the system check result was ok
Big_Rich180
PostPosted: Fri Mar 22, 2013 9:55 am Up
Not the case in my experience, the light on the dash should go off when the ABS reads correctly again.
Had the same issue on my 180 and never had to have the codes cleared to get rid of the light.
PostPosted: Fri Mar 22, 2013 10:02 am Up
The ABS warning light will go out as soon as the ABS ecu see's the fault is fixed.
DREWDEN
PostPosted: Fri Mar 22, 2013 10:11 am Up
Thanks Big Rich180, Gonna clean sensors when i get chance, and go from there.
DREWDEN
PostPosted: Fri Mar 22, 2013 10:28 am Up
Thanks Timon 2210 thanks for your input, but MRBSI and Big R seem to have the opinion of the mechanic.
PostPosted: Sat Mar 23, 2013 3:39 pm Up
No problem mate,keep us posted on how did you got it fixed so that other can find it useful when they do a search in here Very Happy
DREWDEN
PostPosted: Sat Mar 23, 2013 4:34 pm Up
Will do, Gonna check all sensors when this nasty snowy weathers gone.
Looking at forecast another week. Crying or Very sad
nellyhaggis
PostPosted: Mon May 06, 2013 5:31 am Up
How did you get on with this?
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
DREWDEN
PostPosted: Mon May 06, 2013 11:50 am Up
Just got round to sorting it, whipped all four sensors out the other day and gave them all a good clean, with no joy, checked both abs fuses this morning
both ok. My thoughts at the moment is when the rings crack, they become ovaled and bigger, and am therefore assuming, as worn down the sensors a bit,
and am now left with a larger gap between the sensors and ring.
So gonna get 2 new sensors and see what happens.
Anyone know what the gap should be between sensor and ring, tried searching for the answer without success.
PostPosted: Mon May 06, 2013 2:03 pm Up
Unlikely, I think you need a code read to see what the issue is here. Sounds like a sensor failure.
DREWDEN
PostPosted: Mon May 06, 2013 3:00 pm Up
Had it code read a while ago came up front n/s sensor, i am presuming the the fault came up because of the cracked ring, or am i wrong.
Anyhow gonna change front sensors, and hopefully everything will be ok.
cheers Steve
Peachy4878
PostPosted: Tue May 07, 2013 3:08 pm Up
hi drewden i had the same problem last weekand it was a faulty sensor, had abs ring replaced however fault would not remove from dash display. changed the sensor and fault on dash has went away, hopethis helps. gary
DREWDEN
PostPosted: Tue May 07, 2013 4:58 pm Up
Cheers pal, hopefully this thread can be solved after sensors have been changed.
