Online Now [94]:
Visitors: 94
Today: 34302
Total: 138713412
Forums › The Car › 206 Problems › Car cutting out when slowing down!
aidan117
PostPosted: Sat Apr 20, 2013 6:43 am Up
Hey Guys,
I dont know if this has already been posted, but i thought it would be easier to say exactly whats happening to my car rather than try and find one doing similar things.
The problem is, for no apparent reason and without warning, my car will just cut out when slowing down for junctions, roundabouts, and stopping etc. It will normally do when im slowing down past/around 20mph and only happens when im breaking. The Engine cuts and i lose power, everything, including power steering which isnt helpful when turning into a road.
I get no warning lights before hand it just happens, like its a stall. itll happen for a whole journey every couple months then it will be fine no problems whatsoever. nothing. then a couple months or so will pass and Then without warning ill be slowing and itll do it again. I need some advice as to whats wrong with it really if anyone can help? also when i start up again if i dont immediatly apply lots of accelaration itll just cut out straight away again.
Someone Please help, Thanks
PostPosted: Sat Apr 20, 2013 6:48 am Up
Next time it does it try to keep the engine running with the throttle. If you can keep it running then I'd be very confident of it being the idle control valve.
aidan117
PostPosted: Sat Apr 20, 2013 9:08 am Up
Im guessing you mean keeping it running from turning it back on again? And yes if I use the throttle it doesnt cut out but if I dont and just turn it on a leave it idling it cuts after a couple of seconds ?
PostPosted: Sat Apr 20, 2013 11:03 am Up
Well next time it wants to cut out just give it the slightest bit of throttle. Does sound like the idle control valve.
DanT
PostPosted: Sat Apr 20, 2013 1:21 pm Up
My bet would also be on idle control valve, had this issue many times with various TU engines. Can sometimes get away with cleaning it and resetting it but they do need replacing occasionally.
PostPosted: Sat Apr 20, 2013 2:36 pm Up
Stepper Motor for sure :),or a throttle body needs cleaning
DREWDEN
PostPosted: Sat Apr 20, 2013 3:34 pm Up
When was your fuel filter last changed!
206 2ltr Hdi glx 53 plate
aidan117
PostPosted: Mon Apr 22, 2013 6:05 pm Up
Sorry for delay in replying guys, thanks for help not sure when the fuel filter was last changed as ive only had the car 6 months and it hasnt been done whilst ive had it. And okay will look into the idle control valve route, any guesstimates on what this would cost?
cheers
VorTechS
PostPosted: Tue Apr 23, 2013 4:22 am Up
Staff - Vortechs
Almost certainly this. I had this problem a little while ago, a bit of carb cleaner on this and the throttle housing - and I've not had a problem since.
eddie206
PostPosted: Tue Apr 23, 2013 6:22 am Up
Ive had this trouble for ages now but it hasnt happened throughout this crappy snow/cold weather weve had for around 3 or 4 months,just the last week with the weather warming up the damned fault has returned? Im curious to see if it might be a summer/winter setting on the engine intake etc. if they have one??? Mines a 2002. 137gti and if anyone could tell me where to change the winter/summer setting(if it has one?)that would be of great interest thanks guys...
PostPosted: Tue Apr 23, 2013 12:21 pm Up
There is no summer or winter settings. If yours cuts out when slowing down and out of gear then yours will probably have the same problem too.
ra5ax
PostPosted: Wed Apr 24, 2013 3:56 pm Up
I believe this is a Peugeot issue check out this BBC article
news.bbc.co.uk/1/hi/en...106437.stm
also have a look through this site page fair bit on it I have the same issue and will be calling peugeot tomorrow if its what ours ts doing it needs sorting and should be free.
forums.moneysavingexpe...?t=2354331
PostPosted: Thu Apr 25, 2013 6:19 am Up
ICV valve problems don't flag up the ECU light or any fault codes.
aidan117
PostPosted: Sun Apr 28, 2013 1:29 pm Up
So what would you guys say the best way to approach this is?
PostPosted: Sun Apr 28, 2013 2:39 pm Up
Remove it, clean it and the hole it sits in. Very simple.
