Latest: Stu-mill
Overall: 17131
Online Now [108]:
Visitors: 107
Today: 19923
Total: 104656210
Forums › The Car › 206 Problems › Damn 180 steering! Help, please...
gpvecchi
PostPosted: Fri May 17, 2013 2:10 pm Up
There's a problem I can't solve with my RC (GTI 180).
Sometimes steering is soft and perfect, sometimes it becomes hard to pull and when turning (both slowly both fastly) it judders a lot!
Lower arms and all other joints were changed; I assume it is something related to steering pump (it has been changed 5 years ago because of a leakage) but I can't understand why sometimes is good and sometimes is not.
Help, please!
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
PostPosted: Fri May 17, 2013 2:14 pm Up
When it becomes hard to pull, is it when you pull the wheel hard and fast?
gpvecchi
PostPosted: Fri May 17, 2013 2:21 pm Up
In particular, but even if turn slowly in a crossroad.
Even if I stay still and I turn from one side to the other.
Schumi
PostPosted: Mon May 20, 2013 2:22 pm Up
As you know that 206 RC have variable steering assistance. Steering will going harder after 4500 rpm and go slower again when rpm goes below 4000. I dont know exactly how is this working (i think its in inside pump) but maybe your problem is related with that one. I know our steering pump is simple mechanic one instead of electric pas pump but maybe your problem source is pump.
2005 206 RC RED
gpvecchi
PostPosted: Mon May 20, 2013 2:28 pm Up
Thanks, usually pump problem are not intermitting. I think that it could be something related to steering rack that creates overpressure on the steering pipes and make the valve discharge it.
PostPosted: Mon May 20, 2013 6:15 pm Up
If outside / ambient temp seems to make a difference as well, could be the steering valve in the rack in which case it's replacement rack time.
However, Schumi has a point with the pump if it's variable.
gpvecchi
PostPosted: Thu May 23, 2013 2:09 pm Up
Update: I was still in neutral without brakes; I steered from center to left with A LOT of juddering; then I steered from full left to full right without juddering.
Then from full right to full left: no juddering at all... I'm mad about this thing!
PostPosted: Thu May 23, 2013 2:18 pm Up
Maybe one way round it is to fit a shorter belt bypassing the PAS pump. If the dodgy steering still continues with no power assistance then you know it's not a mechanical problem with the rack. It narrows it down slightly to a hydraulic problem.
There's a pressure sensor on the steering pipes. Does Planet Peugeot do more in depth scanning than a normal fault code reader? It might be able to see any surges in pressure.
gpvecchi
PostPosted: Thu May 23, 2013 2:48 pm Up
Good idea, thanks! BTW, no P codes with PPS2000...
PostPosted: Thu May 23, 2013 4:33 pm Up
Yes it does.
Real time data.
PostPosted: Thu May 23, 2013 4:34 pm Up
Either your pump is shaged, or V-belt slipping big style.
Simple.
