Posted: Sat May 18, 2013 1:50 am |
Hi all first post so take it easy on me I have a 206 GTI SP and the clock/radio desplay went I tried to open it up have a general nose around when I pulled the ribbon out now heres the thing the clock in there is a 4 bulb but would a three bulb clock work cause as far as I can see they are the same apart from the number of bulbs???
Posted: Sat May 18, 2013 4:28 am |
in a word no, 4 bulb is the ppt-30 for the pre-plex and the 3 bulb is the ppt-40 and is muti-plex.
its a common problem for the display to play up on the ppt-30, you can DIY fit it, there is a guild somewhere on this forum
| Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1) | |
Posted: Sat May 18, 2013 7:00 am |
Thanks for that info ill try and find the guide
Posted: Sat May 18, 2013 6:06 pm |
| tsotd wrote: |
its a common problem for the display to play up on the ppt-30, you can DIY fit it, there is a guild somewhere on this forum |
Yes, it's called the 206info ppt Guild.
