Latest: Worthy967
Overall: 17143
Online Now [545]:
Visitors: 544
Today: 148379
Total: 114271855
Forums › The Car › 206 Problems › 2.0 hdi antipollution fault
stickman
PostPosted: Wed May 22, 2013 9:28 am Up
Hello all
the last few weeks ive had quite a few anti pollution problems with my 2003 206.
the car would over run when i turn the engine off, and while its ticking over it shudders a little and sounds quite lumpy, the fault comes and goes all the time but i noticed when the engine over runs alot the fault will pop back up the next time i turn off the car, and when i do the car will not rev over 2000 and its a struggle to get the car upto speed, i turn it off again and the fault on the dash still pops up but i can then rev the car as normal.
the only things i can think of are
EGR Valve
Anti Shudder valve
Vacuum Pump
or have i missed anything?
03 China Blue Dturbo
PostPosted: Wed May 22, 2013 12:11 pm Up
Fault code scan, or your p**sing in the wind.
PostPosted: Wed May 22, 2013 2:23 pm Up
I'm sure you got the EML light on,so a Fault code will be best solution in your case,but when you start it in the morning,do you find it hard to run,or run smoothly?
stickman
PostPosted: Thu May 23, 2013 2:25 am Up
i will be getting the fault codes read soon, in the mornings it will either take a while to start and then sound really rough but other mornings it will start up fine and run smoothly. so its a strange problem that me and my old man cant figure out for the life of us. we initially thought that because the HP fuel pump was leaking air was getting into the system and causing it to start rough in the morning, but we have since fixed that but the problem still occurs.
