Latest: lio94
Overall: 17181
Online Now [124]:
Visitors: 123
Today: 76423
Total: 140422108
Forums › The Car › 206 Talk › how hard is it to remove sound proofing
usher
PostPosted: Sun Mar 03, 2013 4:29 am Up
as title has anyone removed it before i put some in the boot as the exhaust was too loud but now wont be a problem
any tips apreciated
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
mtempsch
PostPosted: Sun Mar 03, 2013 6:40 am Up
any tips apreciated
Depends on the quality of the stuff (and its adhesive) you put down, as well as how well you cleaned the surfaces and how well you 'worked' it down...
Poor enough prep-work and/or adhesive makes it easier, but if done well it's bound to be a PITA...
A plastic ice scraper (I prefer the simple rectangular piece of plexiglass(acrylic plastic) might get you down to just above the glue layer, then use chemicals to get that. Be careful about damaging the paintwork.
Why would you want to remove it?
Silvermetallic 2004 206 RC
Schumi
PostPosted: Sun Mar 03, 2013 7:02 am Up
Which kind proofing. Factory sound proofing removing very hard without using dry ice. Becareful when using dry ice and dont touch without gloves or naked hand. Aftermarket proofing can be removed by heat gun. We cant remove 20 year old Nissan factory sound proof dry ice but when removing sound proof from Peugeot 106 with 10 year old only thing we need heat gun and flat spatula.
2005 206 RC RED
Ash
PostPosted: Sun Mar 03, 2013 1:24 pm Up
Does the 106 even have sound proofing? I've literally stripped one today and I couldn't find any. However I did put some sound deadening on.
If its applied properly with a heat gun on a clean surface, it is a total pain in the a*** to remove.
usher
PostPosted: Mon Mar 04, 2013 2:40 am Up
the sound proffing was an ebay special, i cleaned with soapy water then tower dried and applied the stuff
im removing as its now a track car and the sound proofing weighed about 10kg when i got it
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Wed Mar 06, 2013 3:29 pm Up
option b is to just get some acustic carpet to cover the sound proofing and make some hardboard door cards and carpet them
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Mon May 27, 2013 11:24 am Up
update
it came off easily just pulled and it was off
project thread WIP
garage
FAQ
206 gti firedance
