Latest: Stu-mill
Overall: 17131
Online Now [56]:
Visitors: 55
Today: 11282
Total: 104920881
Forums › The Car › 206 Talk › 206 gti wheels
206 gti wheels
omega
PostPosted: Mon May 27, 2013 1:18 pm Up
on a 2001 gti what size wheels and tyres should it have as standard?as mine has aftermarket 17S
cheers
Uz
PostPosted: Mon May 27, 2013 1:22 pm Up
15" Lightnings with a 185/55 R15 tyres
or
16" Nimrods with 195/45 R16 / 205/45 R16
All depends on what mood the frenchies were in on the day and also which side on 2001 it was built.
PostPosted: Mon May 27, 2013 1:25 pm Up
Be warned decent 185/55 15 tyres are getting harder to find & there expensive if you do find them.
Michelin is a now a no go & Goodyear only do 1 tyre in that size.
Uz
PostPosted: Mon May 27, 2013 1:28 pm Up
Continental & Pirelli still have tyres available in that size..
206gti_chris
PostPosted: Mon May 27, 2013 1:30 pm Up
www.setyres.com/ is not bad for prices but i only looked for myself and 195/50/15
omega
PostPosted: Mon May 27, 2013 1:47 pm Up
so a I right in thinking that 16s are the better option due to tyre size then?
at present it has 17s with 40 profile tyres and the ride is to harsh for me[iam old] so am looking for a smoother ride
1245678
I said DECENT tyres Wink
PostPosted: Mon May 27, 2013 1:48 pm Up
A 2001 car should definitely have the 16" Nimrod/Ouragans on it. Most 2000/W plate cars had the 16" wheels too.
omega
PostPosted: Mon May 27, 2013 1:50 pm Up
but mines a 2001 on a y plate
1245678
PostPosted: Mon May 27, 2013 2:48 pm Up
Well if they fitted the 16" wheels to most W platers then all X and Y plate cars should have them too.
PostPosted: Mon May 27, 2013 2:50 pm Up
I've found that if you want the latest sports type tyres you can sometimes struggle to get them in 16". I wouldn't want a normal tyre on a hot hatch. I'll be going for the Dunlop Sport Maxx RT next.
omega
PostPosted: Mon May 27, 2013 2:53 pm Up
oh yes that makes sense Embarassed
1245678
PostPosted: Mon May 27, 2013 2:55 pm Up
I've got a pair of the new Goodyear efficient grip performance to go on the back of the 206 later this week, they seem to get a good write up in many places.
I doubt they will last as long as a Michelin Pilot though.
PostPosted: Mon May 27, 2013 3:15 pm Up
Have you seen the wet braking distances between Eco tyres and normal ones? Even branded tyres are scary.
PostPosted: Mon May 27, 2013 4:31 pm Up
It's A rated for wet braking on the new EU tyre label Wink
