Posted: Sun Jan 11, 2015 10:46 am |
I have a 206gti that has produced a water leak coming from the timing belt side. So I have replaced the water pump but it is still leaking in the same place can any 1 help please
Posted: Sun Jan 11, 2015 11:20 am |
have you replaced the water pump gasket when you replaced the water pump?
Posted: Sun Jan 11, 2015 11:22 am |
Also check the water pump pipe,that goes out from the water pump housing,maybe it need to be replaced
Posted: Sun Jan 11, 2015 11:34 am |
Yes I have replaced the 2 rubber sills that come with the new water pump there was no gasket. The water seems to be coming from the timing belt area
Posted: Sun Jan 11, 2015 12:25 pm |
take the timing belt cover and check it with a light,to see where the leak is,you can pressure test it while engine is cold,and see where the weak point is.
Posted: Sun Jan 11, 2015 12:35 pm |
Ok thanks that was my plan to do through the week
