Latest: Beduff1977
Overall: 17134
Online Now [687]:
Visitors: 686
Today: 167328
Total: 108503472
Forums › The Car › 206 Problems › deleted
deleted
Quikrex
PostPosted: Wed Feb 27, 2013 5:13 pm Up
deleted
PostPosted: Wed Feb 27, 2013 5:40 pm Up
Just under 90 moving, rises to 95 ish before fan kicks in. If its really cold sits around 85. Unless its low on water I wouldn't add more. Also don't forget antifreeze is also a coolant so make sure you've got the right mix in the system.
imjeeves
PostPosted: Thu Feb 28, 2013 5:18 am Up
A car is supposed to run at 90 degrees so wouldnt worry about it.
Quikrex
PostPosted: Thu Jun 13, 2013 5:22 am Up
so are the gti180's prone to head gasket failures like the rest of the bunch? as im thinking thats what i have Sad
imjeeves
PostPosted: Thu Jun 13, 2013 5:32 am Up
no i would not say they were prone to it. The 180 engine is a very strong well designed unit
kipper88
PostPosted: Thu Jun 13, 2013 5:39 am Up
iv just heard from dp engineering that standard internals are good for "
A complete stock engine (with only a decompression package to lower the cr-ratio) can reliably make around 290 - 300 hp on 0.7 bar of boost pressure. This is the most economic power to investment performance level.
my old 180 got a bit hot in traffic as does my current 180 its a very big engine in a very small and poorly vented area so unless you are moving this will always be the case
206 gti 180 project in shutting tits up
Quikrex
PostPosted: Thu Jun 13, 2013 6:29 am Up
deleted
kwakzx7r
PostPosted: Thu Jun 13, 2013 12:49 pm Up
Quikrex wrote:
thanks i thought it was just that also but i do smell a bit of coolant so either i have a leak or its coming the the zorst (hard to tell in the uk with it always being cold lol)
You could be talking about my car from what you have said in this paragraph. In fact tonight when I got home I checked under the bonnet as I could also smell a faint smell of coolant but no visible leaks anywhere Confused
uttz
PostPosted: Thu Jun 13, 2013 6:13 pm Up
its normal imo to pass 90 and go up to approx. 95 when at a stand still but once (atleast in my case) the A/C is running stays around 90 at a stand still, in traffic just creeps up over that
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
