Latest: Stu-mill
Overall: 17131
Online Now [32]:
Visitors: 31
Today: 45486
Total: 104681734
Forums › The Car › 206 Problems › 1.9D Help Juddering / slight judder ?
scottiedickins
PostPosted: Thu Jun 13, 2013 4:28 pm Up
okay guys here we go for around three or four weeks now the car has this random judder it does only when the temp hits around 70 then as it hits normal area around 75 - 80 it drives fine
I should mention that it only also happens when the above and the gas pedal is slightly pressed... when this happens you can hear a notice sound a bit deeper on the exsaughst almost like there's a seal broken or something.
iv checked the egr valve but disconnecting it and trying still same thing the air filters new fuel filters new glows are new pretty much everything is new lol and still the problem is there.
sometimes it can be quite violent then other times not so bad.
im concerned that its gonna cause a knock on affect and damage something else in the process so any ideas Idea or suggestions would be great thanks all.
