Latest: Beduff1977
Overall: 17134
Online Now [380]:
Visitors: 379
Today: 7125
Total: 106997174
Forums › The Car › 206 Problems › ABS Fault 206 1.6 hdi 2005
206HdiGti
PostPosted: Mon Jun 10, 2013 6:49 am Up
Over 90 the abs & esr/asr faults flash up on the mfd - only over that speed for some reason, then they go off after a while after i've turned the ignition off.
Whereabouts is the sensor? Someone mentioned its a magnetic sensor inside the wheel bearing but other places say its a ring on the driveshaft?
I could do the driveshaft myself but not the wheel bearing.
Can anyone confirm which one it is please?
cheers
Lecktorious
PostPosted: Mon Jun 10, 2013 7:05 am Up
Trade Rating: +59
If it's intermittent and only coming on at certain speeds, it will be the toothed ring on the driveshaft.
I've got a brand new one here. Drop me a message if you need it.
'98 Nile Blue 306 GTi 6
206HdiGti
PostPosted: Mon Jun 10, 2013 7:28 am Up
I've got to arrange my MOT for the 4th July which i'm on holiday but will need to buy a radiator (i've been saying that for 6 months now!!) so unless its on permanently i'll wait til its passed.
If you haven't sold it by middle of July I'll contact you Smile
Thank you Smile
DREWDEN
PostPosted: Mon Jun 10, 2013 7:46 am Up
The rings when they crack (split) can damage the sensor as it did on mine because i didn't attend to it straight away.
As a precaution i would check the rings now, if there is one gone i would remove the sensor, then put back on when you get round to fixing the ring.
The rings obviously enlarge when they split and ware away the sensor.
206 2ltr Hdi glx 53 plate
PostPosted: Mon Jun 10, 2013 8:01 am Up
You can get the rings on there own off ebay for about £5-10 each, easy to fit with some patience. Google a company called J&R cv joints, they sell them seperatally as well, or will sell you a complete cv joint with new ring for under £20 delivered, when buying the rings check the size first though as some are 80mm, some are 86mm and others 90mm
Lecktorious
PostPosted: Mon Jun 10, 2013 8:26 am Up
Trade Rating: +59
Thank you Smile
It will still fail mate if the crack is visible.
206HdiGti
PostPosted: Thu Jun 27, 2013 5:03 am Up
Whereabouts is the ring? Can I see it from underneath the car?
PostPosted: Thu Jun 27, 2013 5:20 am Up
It sits around the driveshafts just behind the hubs.
