Latest: tbafonso
Overall: 17130
Online Now [300]:
Visitors: 299
Today: 51130
Total: 104632872
Forums › The Car › 206 Problems › OBD/Live data results
Mr-Tigger
PostPosted: Sun Jun 16, 2013 6:00 am Up
so,im now looking to get to the bottom of the last of the niggles with the gti, had few options come up but wondered which way you guys would sway with the following:
lambda 1 voltage.....all over the place between 0.100 and briefly flickers to 0.600mv
lambda 2 voltage... 0.600mv fluctuating slightly
longterm fuel trim 14.8
short term fuel trim -28
all taken at idle relatively cold but at low idle 850ish.
has obd p0170 (fuel trim bank 1 lean) and i've been blaming ehaust mani leak but now i've seen its actually lambda 1 that seems to be giving the lean running code,im thinking just a plain old pre-cat lambda gone? not happy because the thing did not want to come out last time i tried.
think im on the right lines?
Maqer
PostPosted: Wed Jun 19, 2013 12:41 pm Up
What program did you use to get the lambda values?
I haven't been able to get much data out of my PP2000.
Emission system = no connection (lambda maybe under this?)
Ignition system = no connection
Fuel injection, air intake, driving all have almost every sensor just "???".
Even if engine speed and coolant temp shows on other categories, they are just shown as "???" on others.
Maybe faulty reader or faulty install or not compatible with win7? Argh.
To answer your question, seems like a dodgy lambda to me.
Mr-Tigger
PostPosted: Tue Jun 25, 2013 5:12 pm Up
its a handheld device,gives code and description,along with live data aswell. i thought lambda too,mate gonna whack it up on ramps see if he has any more luck finding a leak than i did first as it would make sense that its blowing but exhaust and centre pipe are def sealed up tight,and the leak would cause erratic lambda read out going lean/rich as it compensates for it
eddie206
PostPosted: Tue Jun 25, 2013 6:27 pm Up
Exhaust mani leak would still have the lambdas showing these off readings...If there is a manifold leak, that needs sorting before you will get true readings anyway!!
Mr-Tigger
PostPosted: Sat Jun 29, 2013 1:26 pm Up
this is what i was saying lol,mate completely forgot so hopefully going in next week,if its a crack or sumat it be getting welded up. hopefully it that simplez
Mr-Tigger
PostPosted: Fri Jul 26, 2013 1:08 pm Up
new mani to flex pipe clamp fitted,no eml and MPG has increased Smile
societydweller
PostPosted: Wed Sep 04, 2013 1:57 pm Up
pp200 dont run on win 7, u need to use virtualbox on win 7 and load pp2000 on to that
PostPosted: Wed Sep 04, 2013 2:28 pm Up
Note: Lambda should fluctuate quite quickly between about 0.1V and 0.7V. A steady lambda is wrong!
PostPosted: Wed Sep 04, 2013 3:33 pm Up
Think you should read how lambdas work. There's nothing wrong with them.
