Online Now [262]:
Visitors: 261
Today: 103175
Total: 143411939
Forums › The Car › 206 Problems › Whining noise (Video)
tom01
PostPosted: Sun Jun 16, 2013 12:52 pm Up
www.youtube.com/watch?...e=youtu.be
Any ideas what the whining noise is?
Also found this unplugged?
206gti_chris
PostPosted: Sun Jun 16, 2013 1:24 pm Up
ive got a simular noise also, i notice mine mostly on the 'over-run' would be interesting to find out whats causing it
206gti_chris
PostPosted: Mon Jun 17, 2013 1:03 pm Up
bump
206gti_chris
PostPosted: Sat Jun 22, 2013 3:38 pm Up
no knowledge from anyone?
eddie206
PostPosted: Sat Jun 22, 2013 10:43 pm Up
When i first listened i couldnt pick it up(maybe others are same hence no response?)but after listenin 3/4times there is a whiney sound and to me if you give all the pulleys etc a good lube up with wd40 and the soynd is still thete it actualy sounds like a bearing to me...now that coyld be a number of things...
So if people watch this over a few times they may be better placed to comment but u could inquire about bearing/pulley/water pump whine as a possible cause?..
NayNay1991x
PostPosted: Sun Jun 23, 2013 7:41 am Up
It's the cambelt I think. Well mine sounds similar to that! And I had a new timing belt kit put on and it whined like that.. And still does when it's hot but garage reckons its normal.. So who to beleive. Get it checked.
206 1.4i GLX 1999
instagram.com/nay206pug/#
mike230272
PostPosted: Sat Nov 02, 2013 7:20 pm Up
Idler pulley needs replacing most probably
