Latest: Puggingalong
Overall: 17129
Online Now [62]:
Visitors: 61
Today: 1067
Total: 100975672
Forums › The Car › 206 Talk › Hatchback and CC rear lights
andyleep
PostPosted: Sun Jun 16, 2013 2:51 pm Up
Are the two different in terms of the electrical connections? I always thought they are the same but I'm asking because I have fitted a CC lamp to a hatchback and the sidelights and brakelights don't work as they should......?
PostPosted: Sun Jun 16, 2013 3:05 pm Up
Should be the same. the only difference is the trim around the light unit
206cc
206 hatchback
meady
PostPosted: Mon Jun 17, 2013 1:13 am Up
Trade Rating: +45
Connections are the same, as I have known many people to fit them before, as said above its just the black plastic trim that's diffrent.
TEAM - I HATE FACEBOOK Smile
gazza82
PostPosted: Mon Jun 17, 2013 4:54 am Up
I swapped out the trim on one to fit a hatchback unit to a CC and it worked fine.
I'd check the connections again or the bulbs. It might be a bad earth. Check the cables haven't been pulled out of the connector block. I think the light just has metal strips to connect to the bulbs .. make sure they aren't being pushed out of alignment either.
If you go from Phase 1 to Phase 2, the connectors are in a different position on the back (vertical rather than horizontal). In the hatch, I had to cut the cable clip to the body or the wire weren't long enough.
