Latest: tbafonso
Overall: 17130
Online Now [318]:
Visitors: 317
Today: 41564
Total: 104092254
Forums › The Car › 206 Problems › Car hunts when hazards on
tommy89
PostPosted: Tue Jun 18, 2013 10:46 am Up
According to the old owner it has always done this.
When I have the hazards on (was dropping off something on a busy street) with the engine on - It hunts and throbs on idle.
Any one else's do this?
as I say - the old owner had it for over 7 years and it has always done it, just wondering if there is a fix.
MrZiggerz
PostPosted: Tue Jun 18, 2013 1:35 pm Up
Mine done it, always thought a better alternator would have fixed it.
tommy89
PostPosted: Tue Jun 18, 2013 3:28 pm Up
Wonder if an alternator can be uprated in any way? might be something to look into possibly - wonder why the hazards are so draining!
Deckchair5
PostPosted: Wed Jun 19, 2013 2:26 am Up
Always best to state car year, engine size etc
But if, when you use headlights or heated rear screen then you don't experience the engine hunting then there's likely nothing wrong with your alternator
If it only happens when you switch on hazards then you have an unacceptable drain in that circuit.
tommy89
PostPosted: Wed Jun 19, 2013 12:43 pm Up
Oh right sorry - thought only one model of 206 had black bumpers - many apologies.
The other electrical items dont make it hunt - Wonder what else is on the same circuit as the hazards!
PostPosted: Wed Jun 19, 2013 1:02 pm Up
The headlights and rear demister are a constant current draw, which may cause the revs to drop slightly and stay dropped until they are turned off, where as the hazards are an on-off drain which may cause the hunting sensation.
Easy enough to check the alternator using a multimeter.
tommy89
PostPosted: Wed Jun 19, 2013 1:42 pm Up
Will do that then Smile thank you - should it remain at a constant voltage when the hazards are on?
PostPosted: Wed Jun 19, 2013 1:43 pm Up
Hazard lights are such a low current though...
tommy89
PostPosted: Wed Jun 19, 2013 2:30 pm Up
Didnt know that either - Oh well. Just wondered if this was a really well known thing with these little cars.
Its done it for the last 7 years so it obviously isn't a massive problem. (old ownser is my sister in law so has no reason to lie) just passed an MOT with it so .... meh.
get what you pay for with a funny little car for £350 Very Happy
