Online Now [236]:
Visitors: 235
Today: 13544
Total: 116626179
Forums › The Car › 206 Problems › Common problem
Common problem
Majid
PostPosted: Thu Jun 20, 2013 3:59 am Up
Hi all
My air filter and housing keep getting wet.
Replaced filter three times now.
Showed mechanic and said the peugeots setup are wrong.
Someone tried solving this before me by gluing and drilling holes.
Mechanic goes rechanelling and buying pipes will be expensive
He gave me two options
1 empty water every couple of weeks. Too much hassle
2 remove air box housing and all pipes below. Replace with universal filter attached to stock intake
I'm going with 2
Any suggestions recommendations?
Any answers will be much appreciated.
PostPosted: Thu Jun 20, 2013 4:01 am Up
Is the deflector rubber thing present on the near-side front lip of the bonnet?
Majid
PostPosted: Thu Jun 20, 2013 4:24 am Up
Yeah cuz it had to be opened to get to the resonator
Peugeot 206, 1.6, 16 valve
2003
PostPosted: Thu Jun 20, 2013 5:02 am Up
Is the resonator on the top part of the engine bay or at the bottom close to the near-side wing?
If the latter, there is no deflector and I can't see why this is happening at all. Is everything definately OK and not broken resonator for eg?
You have to take it completely off to find-out for sure and the 'flute' has to be present and pointing to the back of the car.
Also, you haven't said what model/year etc your vehicle is..
I don't know why people keep doing this and it's slowly starting to p**s me off now because my mind-reading abilities are fading. Laughing
Majid
PostPosted: Thu Jun 20, 2013 5:22 am Up
Hi the resonator is at the bottom near the wheel arch
206 1.6 16v 109hp petrol
2003
My mechanic looked at it and said its just a stupid setup
2003
Majid
PostPosted: Thu Jun 20, 2013 5:26 am Up
Which option would you go for?
I'm thinking of 2. What's the right way of doing number 2 option.
I think I will need a induction kit with oil engine breather pipe hole in it
2003
PostPosted: Thu Jun 20, 2013 5:39 am Up
It sounds like the original factory intake pipe is missing OR has been dicked about with, the air intake is high up protected by the wheel arch liner.
To get water in to the factory air intake system would take water level with the passenger side headlamp to achieve.
Majid
PostPosted: Thu Jun 20, 2013 8:38 am Up
I think that's where the water comes from the side on bonnet channel near headlight
2003
PostPosted: Thu Jun 20, 2013 9:47 am Up
Water shouldn't be able to get in to the air intake system unless a part is missing or damaged.
PostPosted: Thu Jun 20, 2013 10:28 am Up
Yes, sounds like missing 'flute' which is common.
No way should this be happening.
PostPosted: Sat Jun 22, 2013 6:56 am Up
+1 to all above. this should not be happening on a correct factory set up.
Fit an after market system if you choose but in all probability that will only cause you to loose power! While the after market cone filter may be able to pass more air that air will be very hot (it's from right under the bonnet) so less dense.
Follow the advice of those above and make sure it is factory standard; probably easiest way is to compare your set-up against a mate or against a couple of cars in a scrappy.
Majid
PostPosted: Tue Jun 25, 2013 3:25 am Up
Hi
When I remove the airbox that my filter site on
How many pipes will there be underneath?
What they called
2003
