Posted: Thu Jun 20, 2013 10:34 am |
Im Fitting my manifold weekend is it worth me doing my cam belt it needs doing its on 72k not sure if been done?
Cheers
Posted: Thu Jun 20, 2013 10:44 am |
well worth it! Chances are it hasnt been done!
Posted: Thu Jun 20, 2013 10:47 am |
iainlovatt wrote: |
well worth it! Chances are it hasnt been done! |
How easy it it once the cover is off and i have made room to get in there?
cheers
i have heard you need a special tool?
Posted: Thu Jun 20, 2013 10:48 am |
Zack wrote: |
iainlovatt wrote: |
cheers
i have heard you need a special tool? |
You are already sounding out of your depth if you have to ask that type of question.
Posted: Thu Jun 20, 2013 10:56 am |
MrBSI wrote: |
Zack wrote: |
iainlovatt wrote: |
cheers
You are already sounding out of your depth if you have to ask that type of question. |
I have been working on cars all my life and never done a cam belt reason being am all ways like what if i do it wrong so what as much in as possible.
cheers
Posted: Thu Jun 20, 2013 11:18 am |
Have fun, the 138 uses a floating crank, not the simplest of things to lock in place if you don't know what your getting yourself into.
Posted: Thu Jun 20, 2013 11:59 am |
it can be done tho the thing is its not impossible so dont no what to do someone on here must have done it
Posted: Thu Jun 20, 2013 1:14 pm |
I struggled to get the belt covers off mine and it has no air conditioning pipes. I'm sure the engine needs taking off the mounts to provide enough clearance to get the belts off otherwise.
Posted: Thu Jun 20, 2013 1:25 pm |
Edward wrote: |
I struggled to get the belt covers off mine and it has no air conditioning pipes. I'm sure the engine needs taking off the mounts to provide enough clearance to get the belts off otherwise. |
Somehow the cover worked itself loose on mine, started it up outside work one day and luckily still had the door open to hear something fall off. Switched it straight off and popped the bonnet to find the whole top cover dropped down almost resting on the belt. Even with the top mount off I struggled to get even a miniature socket set in at some of the screws.
Posted: Thu Jun 20, 2013 1:35 pm |
LeeThr wrote: |
Edward wrote: |
Somehow the cover worked itself loose on mine, started it up outside work one day and luckily still had the door open to hear something fall off. Switched it straight off and popped the bonnet to find the whole top cover dropped down almost resting on the belt. Even with the top mount off I struggled to get even a miniature socket set in at some of the screws. |
In going to be removing all the engine mounts to move the engine for the manifold that's why I thought be go plan to do belt
