Latest: lio94
Overall: 17181
Online Now [71]:
Visitors: 70
Today: 34075
Total: 141416710
Forums › The Car › 206 Problems › SERVICE BOX
SERVICE BOX
DREWDEN
PostPosted: Thu Jul 04, 2013 2:28 pm Up
Been trying to remove a bolt with an alan key without success, so looked in Service Box and found the part i am trying to remove ( socket cheesehead screw 10X150-30) anyone knows what tool removes these please.
206 2ltr Hdi glx 53 plate
PostPosted: Thu Jul 04, 2013 2:52 pm Up
I'm guessing you need a 'socket cheesehead' screwdriver.....
DREWDEN
PostPosted: Thu Jul 04, 2013 3:42 pm Up
Thanks for that E5GDM.
Bit more force needed than a screwdriwer, trying to remove the rear suspension rebound rubbers and brackets, which are fixed with a sturdy bolt, with an hexigon recess.
Alan keys i have tried seem not to grip, and probably end up rounding them off if i carry on.
Anyone removed these before.
Hawkers
PostPosted: Thu Jul 04, 2013 3:50 pm Up
Are you sure its not torx screwdrivers you're looking for? The star shaped ones.
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
DREWDEN
PostPosted: Thu Jul 04, 2013 4:30 pm Up
Probably, i have a set but nowhere near large enough.
Pop and see my garage i use tomoz, and see if he will kindly loosen them for me, then charlie browns.
Having the right tools saves a lot of hassle, but then again costs a fortune.
PostPosted: Fri Jul 05, 2013 2:55 am Up
DREWDEN wrote:
Pr
Shagging the fixings by using the wrong tool also can cost a fortune if you have to start drilling bolts out / seek specialist help.
