Latest: Kifi69
Overall: 17183
Online Now [549]:
Visitors: 548
Today: 6013
Total: 143677949
Forums › The Car › 206 Problems › Blleding Brakes with a Air Brake Vacuium Tool
Lizard2010
PostPosted: Sat Jun 22, 2013 8:20 am Up
Has anyone used the Blleding Brakes with a Air Brake Vacuum Tool
To bleed brakes on a 2002 206 GTI 2.0
As below from ebay
www.ebay.com.au/itm/Ai...4985528%26
Thanks in advance
Owner of a 2001 Peugeot 206 GTI 2.0 16v
PostPosted: Sat Jun 22, 2013 9:30 am Up
I've used a normal eazibleed kit...works fine.
DREWDEN
PostPosted: Sat Jun 22, 2013 9:32 am Up
Think you need PEUGEOT PLANET to bleed your brakes.
206 2ltr Hdi glx 53 plate
macj
PostPosted: Sat Jun 22, 2013 10:13 am Up
No you don't.... just use the eezibleed or any pressure system
This one is excellent and I have one in the service van all the time
www.ebay.co.uk/itm/251...1439.l2649
PostPosted: Sat Jun 22, 2013 10:54 am Up
Is this to bleed the system or just change the fluid?
PostPosted: Sat Jun 22, 2013 2:13 pm Up
It's easier to bleed the system with ABS using the PP2000,as it will control which wheel to bleed,and open the ABS Pump,the pressure tool just to make it done by one person instead of 2 ppl to do it,as you will need one to push the brake pedal till it get hard and keep the foot on the pedal while someone else open the bleeding point.
Lizard2010
PostPosted: Sun Jun 23, 2013 12:43 am Up
Just to change the fluid.
My Son has one for a Australian car. Same as UK Kit.
Lizard2010
PostPosted: Sun Jun 23, 2013 12:44 am Up
Thanks to all for the quick responses.
My son was not sure if it did anything to do with the Computer System.
I don't think it will.
