Online Now [597]:
Visitors: 596
Today: 158286
Total: 146860801
Forums › The Car › 206 Problems › Gti 180 Fault code P0410
DenW
PostPosted: Mon Jan 23, 2017 12:11 pm Up
If anyone can help with this I will be eternally grateful..fault code on gti 180 P0410 intermittent fault on the secondary air circuit..is this a simple case of changing the air pump?.Symptoms include intermittent loss of power engine sounds 'flat' no induction noise seems to be worse when engine is cold tends to improve as it warms up though it can still do it when it's warm..feels like a flap is sticking, checked and cleaned the throttle body all ok...put foot down and and there's virtually no acceleration then all works OK...help!
yokel
PostPosted: Sun Feb 12, 2017 11:55 pm Up
Do you have a standard airbox or induction kit? Have any of the secondary pump pipes come lose? Have they been taken off at any point?
DenW
PostPosted: Mon Feb 13, 2017 1:07 am Up
Thanks for replying ...standard airbox with a kn panel filter as far as I'm aware all pipes are ok
