Posted: Wed Jun 26, 2013 9:27 am |
Trade Rating: +13
So just had the car into the dealers and they only found one issue.
Slight leak on the head gasket.
They have quoted me
Cyl head gasket x1 part PE00000209FL
Cyl head bolt x 10 part PE00000204A5
Gasket rock x1 part PE00000249E2 I have no idea what this is?
Gasket rock x1 part PE00000249C5 I have no idea what this is?
Exh bkt seal x1 part PE0000170933 I have no idea what this is?
Cool liquid x3 part PE00009735K1
Total parts £89.11 + vat
Labour 8hrs @ £82/hr = £656 + vat
Total price £894.13
I think not!
My neighbour has done several head gaskets and rebuilt a couple of engines, so he has told me to get the parts and he will do it with me over a weekend.
I have a Haynes manual, is there anything specific to a 206 we need to be aware of please?
Posted: Wed Jun 26, 2013 10:03 am |
| Tolkienfan001 wrote: |
2 x rocker cover gaskets & 1 x exhaust gasket
Posted: Wed Jun 26, 2013 10:04 am |
Trade Rating: +13
| MrBSI wrote: |
2 x rocker cover gaskets & 1 x exhaust gasket |
Thank you very much as ever your knowledge is second to none!
Posted: Wed Jun 26, 2013 10:06 am |
I noticed they haven't quoted for a timing belt kit, normally if your going to all the trouble to change the cylinder head gasket you would do the timing belt at the same time while the engine is apart - unless the belt has alrwady been done very recently.
Posted: Wed Jun 26, 2013 10:14 am |
Trade Rating: +13
It was done last October...
Posted: Wed Jun 26, 2013 10:49 am |
well realistically what exactly needs doing? How bad are the affected areas that they have mentioned.
Posted: Wed Jun 26, 2013 10:54 am |
Trade Rating: +13
They just said the head gasket has a slight leak? Cp4less have a kit for £55 delivered. And my neighbour will do the job.
Posted: Wed Jun 26, 2013 1:08 pm |
£82 an hour for labour??
Holy fecking jeezus christ what stealership was that?
| Yes I own a CC and I'm neither gay or a hairdresser!! | |
Posted: Wed Jun 26, 2013 1:17 pm |
Trade Rating: +13
Marshall Peterborough
Posted: Wed Jun 26, 2013 4:05 pm |
Buy the parts yourself from the cheapest source and get someone from here to do it? Even if you have to travel 250 miles (the extreme!), it would well be worth it. Maybe a 250 pound total bill instead of 900...
| Own a Blue Peugeot 206 GTI 180. | |
Posted: Wed Jun 26, 2013 4:27 pm |
6 litres of anti-freeze? At Pug in Tewkesbury we tend to do 3 litres of 1 litre bottles (9735K4) for head jobs.
Trade Rating: +13
I can get a full kit for £82. And my neighbour will talk me through it.
Not sure what to go about skimming the head? Some say yes some say won't know till I see it??
Posted: Wed Jun 26, 2013 5:33 pm |
I will point out every TU has an oil leak. About 15k they leak, so even if you do replace it will just leak again
| Team Impossible Possible
Posted: Wed Jun 26, 2013 11:19 pm |
Trade Rating: +13
Do should I leave it?
Posted: Thu Jun 27, 2013 5:10 pm |
Personally I would replace it eventually. But for the majority of the time I would just clean the block and let it continue
