Online Now [241]:
Visitors: 240
Today: 10515
Total: 138579111
Forums › The Car › Request a how-to › Injectors removal
Injectors removal
Forum IndexRequest a how-to
Majid
PostPosted: Fri Jul 05, 2013 1:57 am Reply with quote Up
Hi
How do I remove injectors in my 1.6 xsi
I need a step by step guide
So far I know to
Remove the six screws on top of rocker cover
Then remove breather pipes by depressing yellow clips
Then remove coil pack connector
Then remove spark plugs
What do I do next?
What else is there to remove? And where is these item located?
Cheers
Peugeot 206, 1.6, 16 valve
2003
PostPosted: Fri Jul 05, 2013 3:05 am Reply with quote Up
I'm not 100% as it's an engine I'm not familiar with, but aren't the injectors located on the inlet manifold?
What He Said
Majid
PostPosted: Fri Jul 05, 2013 3:18 am Reply with quote Up
What does the inlet manifold look like?
2003
PostPosted: Fri Jul 05, 2013 3:23 am Reply with quote Up
Its under that big black box at the back of the engine.
PostPosted: Fri Jul 05, 2013 3:28 am Reply with quote Up
I think you should put your tools down straight away.
With all respect, well done for having a go yourself, but if you need to ask what the inlet manifold looks like, then you don't have a clue what you are doing.
Best advice is that if you want something doing, put your hand in your pocket and let someone with the knowledge and skills sort it out for you.
  Quick Reply
Username:
Message:
Quote the last message
