Online Now [143]:
Visitors: 142
Today: 67169
Total: 143193627
Forums › The Car › 206 Problems › 5 door hatchback rattle
dave395
PostPosted: Sat Jun 29, 2013 5:18 pm Up
ref 206/ year2003 5 door.I have a bad rattle from what appears to be the back hatch/boot door cannot figure a way of adjusting it to fit better and not be so loose.any ideas would be welcome.thanks
Lecktorious
PostPosted: Sat Jun 29, 2013 7:13 pm Up
Trade Rating: +59
Boot rattle is a common issue. If you search the forum you'll find your answer.
'98 Nile Blue 306 GTi 6
PostPosted: Sun Jun 30, 2013 7:57 am Up
The answer is bin the striker, then fit and carefully adjust a new one. (66 letters)
Ferdasyn
PostPosted: Sun Jun 30, 2013 11:49 am Up
I recently had a thumping noise coming from the rear of mine - at first I thought it was the boot/parcel shelf but it turned out to be the rear axle bushes deteriorating and causing it to bang. Cost me £15 for two bushed off eBay and £30 to have them replaced.
dave395
PostPosted: Sun Jun 30, 2013 2:03 pm Up
Thanks for info.will follow up.thanks again
daykes1
PostPosted: Mon Jul 01, 2013 8:03 am Up
I had the rattling rear bootlid & so I adjusted the black locking mechanism (where the alarm sensor/wire attaches to) Big torx screws - my problem was solved!
PostPosted: Mon Jul 01, 2013 11:35 am Up
My daughters was rattling from what I first thought was boot, then I thought petrol filler cap. It turned out to be poorly fitting rear seat latch. The folding rear backrest was not fully latching unless slammed into position.
dave395
PostPosted: Mon Jul 01, 2013 3:24 pm Up
Many thanks,every thing will help me sort it .thanks again
