Latest: tbafonso
Overall: 17130
Online Now [180]:
Visitors: 179
Today: 49351
Total: 104631094
Forums › The Car › 206 Problems › 206 Diesel hdi 1.6 broken ???
Go to page Previous  1, 2
Lecktorious
PostPosted: Fri Jul 05, 2013 5:08 pm Up
Trade Rating: +59
Addaz wrote:
Some of the ideas eddie206 is throwing out nowadays........
Edited for accuracy and truth.
'98 Nile Blue 306 GTi 6
Jack123
PostPosted: Fri Jul 05, 2013 5:26 pm Up
Addaz wrote:
Some of the ideas people are throwing out nowadays......... I would be checking fap pressures, boost lines for turbo failure (oil blocking them) and see if the ecu is unlocking
Laughing
There could be numerous issues causing it, if it died while you were driving it then were there any prior issues? Did the revs drop suddenly before it died? Did anything strange happen before it died? Best thing to do is get the error codes read.
Not sure if I am taking out of my a**e here or not, but it would still start with a faulty turbo, and just cut out when you give it a good amount of revs, no?
Not 100% sure, never owned or worked on a car with a turbo, never needed the knowledge Embarassed
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
DREWDEN
PostPosted: Fri Jul 05, 2013 5:45 pm Up
If this situation had happened to me, my first port of call would have been to clean the engine dipstick, and dip the fuel tank, to see where i was with the diesel.
I assume the car as been sorted now, and hopefully she can say what it was.
206 2ltr Hdi glx 53 plate
eddie206
PostPosted: Sat Jul 06, 2013 6:48 am Up
EXCUSE ME HERE..IS THIS A CONSPIRACY OR WHAT?????
ADDAZ DOESNT EVEN SAY"SOME OF THE IDEAS EDDIE206 IS THROWING OUT"???
WHAT ARE YOU SAYING???OR IS THAT THE EDITED VERSION???
AS FOR STRANGE IDEAS..AS FAR AS MY COMMENT WENT.......I SUGGESTED PUTTING £5 OF DIESEL INTO THE CAR..THEN I SAID TO PUMP THE LIFT PUMP LIKE THE GUY ABOVE MY FIRST COMMENT HAD STATED...
THIS IS PERSECUTION AND IM DUE AN APOLOGY I BELEIVE...IF NOT FROM EDITOR THEN FROM ADDAZ...ONE OF WHOM IS WRONG HERE....COME ON FELLAS SORT IT OUT...
PostPosted: Sat Jul 06, 2013 6:54 am Up
At least this is a new forum record for a 1.6 HDI breaking down after purchase Rolling On The Floor Laughing
Essex1
PostPosted: Thu Jul 11, 2013 5:36 am Up
Hello
Thanks for all your replies. The ECU connections were loose, apparently!!!
Runs fine now
Ali_H
PostPosted: Thu Jul 11, 2013 5:42 am Up
Don't hold your breath, or do. Either way.
BTW, fix your keyboard.
kurtis wrote:
206HdiGti
PostPosted: Fri Jul 19, 2013 5:59 pm Up
YAY you've beaten my record! LOL
I have got an issue, but its not directly connected to a 1.6 hdi
To be fair, mine apart from the DPF issue has been fault free, apart from electrical issues which pugs are known for.
Page 2 of 2
