Latest: Stu-mill
Overall: 17131
Online Now [65]:
Visitors: 64
Today: 17999
Total: 104807418
Forums › The Car › 206 Talk › Turbo build parts needed
lee1985
PostPosted: Fri Jul 05, 2013 2:09 pm Up
Wondering if someone nice enough can tell me exactly what parts I need to purchase in order to have all the equipment ready for a bolt on turbo I.e. all I need then is someone to put it all together.
Okay so a garratt turbo (either the 28 or the 30 would be enough I think)
Upgraded injectors?
Turbo manifold
Some sort of hoses I believe, clips and other bits and bobs
Obviously an ECU and rolling road mapping
Etc...
Not sure if I'd need forged pistons and rods as I'm only looking for an output of between 280 and 320 but someone can advise?
But I really need someone to tell me exactly what parts I need, without missing anything essential.
I've been changing my mind like the wind blows but clearly the cheapest way forward is to source the parts myself then just pay the right experienced guy for fitting when I'm ready.
I really want to go through with this but it's stupid if I don't even know what to buy. Looking at the build of project cars doesn't tell much, some parts are arguably not needed and often a bespoke version provided by that Motorsport dealer I.e their own product. So I just need a simple but effective list
Thank you
usher
PostPosted: Fri Jul 05, 2013 2:21 pm Up
you can look on dpengineering for ideas on cost
the manifold is 850 euros alone btw
DP
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Fri Jul 05, 2013 2:28 pm Up
Your gonna need to lower the compression ratio whatever you do so the head's gotta come off even if it's just to fit a decompression plate. But if your going to do it, may as well do it properly and get forged pistons etc in there.
206gt160
PostPosted: Fri Jul 05, 2013 3:17 pm Up
I'm going down this route with my gti and I would so forged low compression pistons is a must.
I also agree with DP engineering being very good. The manifold foe the gti comes to around £1000 with the add on parts.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
usher
PostPosted: Fri Jul 05, 2013 4:18 pm Up
what about using the 180 bottom end as its stronger not sure wether it has been done but it has been spoken about
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Fri Jul 05, 2013 4:56 pm Up
Budget a good 2k for a home build, 5k if your paying someone
T18sty_206
PostPosted: Fri Jul 05, 2013 5:52 pm Up
Or just give me 5k for this and use all the running gear Wink
www.pistonheads.com/cl...ar/1459334
lee1985
PostPosted: Fri Jul 05, 2013 5:55 pm Up
Thanks for the replies guys
The only thing which puts me off forged pistons is that if I ever want to upgrade to higher boost, low compression pistons will be useless as I will require higher compression? Unless that's wrong.
So, I've got the Garrett GT28R turbo and the EW turbo manifold with the additional extras in the basket so far and including VAT it's 2,200 euros which is probably around £1,800 maybe?
I still need a list of other essential parts for the build, what else do I need to purchase in order to get this up and running?
Next things I think I need are injectors and an intercooler but if so which ones? What about hoses/seals/wiring y'no all the niggly stuff to connect it all?
Own a Blue Peugeot 206 GTI 180.
kipper88
PostPosted: Fri Jul 05, 2013 6:09 pm Up
any inter-cooler as there is no 206 petrol cooler apart from dp version which is pricy go for a common vag cooler and custom pipe job
206 gti 180 project in shutting tits up
kipper88
PostPosted: Fri Jul 05, 2013 6:10 pm Up
this should help you
kipper88
PostPosted: Fri Jul 05, 2013 6:11 pm Up
A complete stock engine (with only a decompression package to lower the cr-ratio) can reliably make around 290 - 300 hp on 0.7 bar of boost pressure. This is the most economic power to investment performance level.
Parts we can offer to reach 280 - 300 hp and around 380 nm;
EW 16v Turbo Package
€ 2.442,00
€ 2.905,98
EW 16v Package stainless manifold upgrade
€ 191,83
€ 228,28
Turbo upgrade to Garrett GT28RS (GT2860RS) BB turbocharger, T2 turbine a/r .86, internal WG, incl. actuator
€ 148,99
€ 177,29
Downpipe option; flange connections (including extra weld flange , gasket and fasteners)
€ 38,53
€ 45,85
Heat Wrap - 50' x 2" x 1/16" - White
€ 58,43
€ 69,54
Thermo Sleeving 1 metre x 22 mm ID
€ 25,00
€ 29,75
Thermo Sleeving 1 metre x 35mm ID
€ 32,00
€ 38,08
Thermo Sleeving 1 metre x 50mm ID
€ 37,00
€ 44,03
TiAL Q Blow Off Valve 50mm, Al or Steel Weld Flange included
€ 204,90
€ 243,83
Decompression package EW10J4 (1997cc 16v) 9.2 : 1
€ 223,60
€ 266,09
Intercooler Peugeot 206, 60 pipe, core 550x250x50 1 row, size 690x250x60 mm
€ 651,36
€ 775,12
Spal high output slim fan for use with Peugeot 206 intercooler
€ 82,00
€ 97,58
Peugeot 206 RC, GT28RS - GT3076R, aluminum charge piping including Silicone hoses and ancillaries
€ 252,35
€ 300,30
Weight 43 kg
€ 0,00
€ 0,00
TOTAL
€ 4.387,99
€ 5.221,71
Fuel parts for up to 350 hp;
Injector set (4) Siemens 663cc injector, high impedance
€ 326,86
€ 388,96
Siemens fuel pump + filter, 300L/H, high pressure Turbine
€ 116,59
€ 138,74
Weight 1,8 kg
TOTAL
€ 443,45
€ 527,70
If you live outside the EU, you can order our parts without Dutch VAT (19%).
Besides the parts above you will also need a programmable standalone engine management system (or custom ecu remap) and a stronger clutch (we have several options available) along with some misc. small parts (small water hose modifications).
As with everything, the further you want to stretch the power output of the engine the more modifications need to be made. If you have different power requirements please inform about the possibilities and parts required.
The parts above are meant to be used with the stick and rod gear change mechanism of the 206 GTi, not the cable shift from the RC. It is however possible to retain the cable shift mechanism, but some modifications are needed. However we suggest swapping to the stick and rod mechanism since this system can be easily swapped and is more reliable to use. (parts can be bought new from us or any Peugeot / Citroen dealer for 182,- euro excl. VAT)
Of course it is also possible to have a complete conversion performed by us in our workshop, again inform about prices.
If you have any other questions about the parts or you want to order something, don’t hesitate to contact us.
Best regards,
Pieter Oonincx
DP-Engineering
Expeditieweg 14-05
6657 cool
Boven-Leeuwen
The Netherlands
Tel. +31 (0) 48 7506045
info @ dp-engineering.nl
www.dp-engineering.nl
