Latest: eltel666
Overall: 17146
Online Now [87]:
Visitors: 86
Today: 17846
Total: 116209423
Forums › The Car › 206 Talk › Peugeot Planet?
Peugeot Planet?
buseng
PostPosted: Tue Aug 13, 2013 4:06 pm Up
I haven't looked underneath but these are the numbers off the top.
ecu
buseng
PostPosted: Fri Aug 16, 2013 6:52 am Up
A bit of an update. Using the same kit/software/laptop I tried it on a friend's 05 plate 206 HDI. Putting his DAM number in, it found his engine ecu no problem.
So it must be an issue with my car causing my engine ecu not to "talk" properly to the test gear. As I said it knows the ecu is there with faults present, but cannot identify or read it.
My DAM number is inputted correctly.
His car was built around 6/7 months before mine.
buseng
PostPosted: Mon Aug 19, 2013 3:08 pm Up
Still getting nowhere with this. I have even reset the BSI following the correct procedure. Still my engine ecu comes up as "unknown reference". I presume it's to do with the car as another 206 I tried works ok as I said. Clutching at straws I'm afraid especially as it says presence of faults. I'm 99.9% sure it is a KFW S2000.
Leegsi
PostPosted: Mon Aug 19, 2013 3:22 pm Up
Does the 206 have a fuse for the OBD port as I know Vauxhalls do and the main dealers take the fuse out so the ecu cant be accessed.
buseng
PostPosted: Mon Aug 19, 2013 3:46 pm Up
I'm not sure, but all the other ecu's can be accessed ok. Various "appropriate" fuses are mentioned in the handbook. I've checked all those both inside the car & under the bonnet. They all seem ok.
PostPosted: Tue Aug 20, 2013 12:11 am Up
I to have a KFW with S2000, ill fire up my Planet later this afternoon & see what it says.
I'm on Planet version 25.01
PostPosted: Tue Aug 20, 2013 9:38 am Up
My version 25.01 Peugeot Planet works perfectly fine with my 2003 vintage Sagem S2000 ecu that is connected to my TU3 KFW lump.
Picks it up on global test & also can go in manually with no issues.
My PSA interface firmware is 4.2.2
buseng
PostPosted: Tue Aug 20, 2013 9:53 am Up
Thanks for the info.
It didn't work on my car with firmware 4.2.2 or currently 4.3.0.
Neither does any version of PP2000 including 25.01 like yours or currently the version in Diagbox 7.02.
As all the other ecu's show ok & it picks up the engine ecu on another (diesel) 206, I think my car must be at fault.
The only other thing I could try is another PP2000 kit, but I don't know anybody else with one. I am in the Reading area if that's any help.
Whether a hand held generic code reader would work I don't know, do not want to buy one for nothing.
PostPosted: Tue Aug 20, 2013 9:55 am Up
Dont later versions of Diagbox need the PSA interface flashing so they work correctly? Confused
Flashing the interface is a different thing to just changing the firmware.
buseng
PostPosted: Tue Aug 20, 2013 10:28 am Up
Not sure about that, but as I said even in the same set up as you - 4.2.2 & PP2000 25.1 - it still doesn't work.
PostPosted: Tue Aug 20, 2013 10:54 am Up
Are you 100% sure you have a S2000 ecu?
Someone might have changed it for a replacement one due to a fault & fitted the wrong one.
Pop the ecu out & get the id numbers of it is the next step.
buseng
PostPosted: Tue Aug 20, 2013 11:14 am Up
I have a picture of it. But can't seem to upload it on here.
Putting a Flickr url in only shows a blank icon.
PostPosted: Tue Aug 20, 2013 11:21 am Up
Use Photobucket instead - its FREE.
buseng
PostPosted: Tue Aug 20, 2013 1:29 pm Up
Managed it! My engine ecu.
PostPosted: Tue Aug 20, 2013 4:17 pm Up
I get the feeling that ecu may have come of a Citroen C3 or Pug 307.
Page 2 of 3
