Latest: tbafonso
Overall: 17130
Online Now [282]:
Visitors: 281
Today: 39669
Total: 102447930
Forums › The Car › 206 Problems › GTi 180 alternator
GTi 180 alternator
206gt160
PostPosted: Sun Jul 14, 2013 11:59 am Up
Does anyone know What the plug is for on the 180 alternator.. On the 138 there is an earth and power lead.
206gt160
PostPosted: Sun Jul 14, 2013 1:38 pm Up
Anyone know
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Indigo_GTI
PostPosted: Sun Jul 14, 2013 3:29 pm Up
its a straight swop for a 138 as far as i'm aware. you modded your 138 alt i recall, you just need to reinstate the wiring connector as it was
206gt160
PostPosted: Sun Jul 14, 2013 3:40 pm Up
I did but I got a 180 alternator for £16 And it will look neater.. There different to each other the 180 has a plug and the 138 doesnt.
206gt160
PostPosted: Mon Jul 15, 2013 5:00 am Up
Anyone?
Indigo_GTI
PostPosted: Mon Jul 15, 2013 6:14 am Up
take a pic maybe? i have a 180 atl on my 138 - its a definetly a direct fit for the 180 altenator of type i have
206gt160
PostPosted: Mon Jul 15, 2013 2:54 pm Up
www.ebay.co.uk/itm/199...19dee17aae
The link above is the alternator I have with no plug connection from a138 1999 reg where as some 138 have a plug connection like the 180 as below this is a 138 2001 reg
www.ebay.co.uk/itm/PEU...27d4dee870
This one below is the 180
www.ebay.co.uk/itm/Peu...41722308be
Any idea of how I would connect mine was thinking of removing a bolt and putting the earth behind it :/
206gt160
PostPosted: Thu Jul 18, 2013 2:49 am Up
Anyone know about what i would do with my alternator having no plug?
Pics above
PostPosted: Thu Jul 18, 2013 6:13 am Up
Fit it and see if it's just for switching the battery light off...
206gt160
PostPosted: Thu Jul 18, 2013 9:39 am Up
good shout Edward I'll give it a try, it might just be that.
