Latest: sparrowdclxvi
Overall: 17139
Online Now [99]:
Visitors: 98
Today: 27753
Total: 113196477
Forums › The Car › 206 Problems › 206 won't start!
206 won't start!
nellyhaggis
PostPosted: Fri Jul 19, 2013 2:42 am Up
Has anyone had a 206 which runs rough when it gets warm and then just stops?
I can leave it overnight and then it starts first turn of the key in the morning.
It's driving me nuts. Its a 206 hdi 1.6.
Any help would be greatly appreciated.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Fri Jul 19, 2013 7:54 am Up
I would be checking for codes to start with. Then injector leak off
rlees85
PostPosted: Fri Jul 19, 2013 12:39 pm Up
The only thing I know that can literally stop a HDI engine is a problem with the rail pressure (so sensor/regulator fault). This would almost 100% turn on the engine light. If you have no engine light I have no idea
PostPosted: Sun Jul 21, 2013 3:50 pm Up
Crank position sensor breaking down when hot. Not sure if that is a common problem on these but it is on many, many makes of car both petrol and diesel. That would be my starting point but, as other posts above, I would expect a fault code.
