Latest: Kifi69
Overall: 17183
Online Now [365]:
Visitors: 363
Members: 1
Today: 28958
Total: 143577695
Forums › The Car › 206 Problems › sticking fuel gauge
sticking fuel gauge
206HdiGti
PostPosted: Fri Jul 19, 2013 5:55 pm Up
2005 hdi 1.6
I've had this a couple of times and each time its sorted itself out.
Its constantly on empty basically even though i put in 2 gallons.
Any ideas?
PostPosted: Sat Jul 20, 2013 1:18 am Up
you need to check your fuel pump,cuz the fuel leveler is in there
PostPosted: Sat Jul 20, 2013 2:13 am Up
How much does 2 gallons cost? If mines on low, it won't register £10 of fuel.
206HdiGti
PostPosted: Sat Jul 20, 2013 6:34 am Up
Mine does register normally on 2 gallons.
Checked the ohmage on the fuel sender unit, all seems okay with the ratings I found online.
Will throw about £40 in today and go over a bumpy road as my float may be the issue.
Cannot get the sender out as it's tight as f*ck!
206HdiGti
PostPosted: Sat Jul 20, 2013 6:37 am Up
Anyone know where I can get the special tool from as well?
DREWDEN
PostPosted: Sat Jul 20, 2013 7:16 am Up
screwdriver and hammer, if i remember rightly it has 1 or 2 chunky lugs that you hit with.
Mine was tight, but with a bit of calm, loosens slowly.
206 2ltr Hdi glx 53 plate
DREWDEN
PostPosted: Sat Jul 20, 2013 7:18 am Up
Forgot to mention mark it, so you know how tight it goes back on.
206HdiGti
PostPosted: Sat Jul 20, 2013 7:32 am Up
A few tabs snapped on mine, so didn't want to completely ruin it when I used hammer and screw driver.
DREWDEN
PostPosted: Sat Jul 20, 2013 7:55 am Up
Did you depressurize the fuel system, before you attempted.
206HdiGti
PostPosted: Sun Jul 21, 2013 5:06 am Up
It's okay now 32 litres moved the float.
