Latest: tbafonso
Overall: 17130
Online Now [113]:
Visitors: 112
Today: 49038
Total: 102786006
Forums › The Car › 206 Talk › Non-OEM lambdas
Non-OEM lambdas
Mr-Tigger
PostPosted: Sat Jul 27, 2013 1:52 pm Up
i know the usual rant is "pug or oem only" but has anyone had experience of or with non-original lambdas,cashflow is a bit tight and seen FAE on euro, there are a few used oem ones knocking about fleabay but im a bit skeptical about this sort of part second hand
PostPosted: Sat Jul 27, 2013 2:15 pm Up
I got a Volz post cat sensor from here a few months ago. Not had any issues yet.
myworld.ebay.co.uk/autosense/
PostPosted: Sat Jul 27, 2013 2:40 pm Up
I have used Intermotor for mine,and it works perfect Smile
PostPosted: Sat Jul 27, 2013 3:02 pm Up
Do thy have plugs that fit the Peugeot loom? If not a 4 way Superseal will do the job.
PostPosted: Sat Jul 27, 2013 3:10 pm Up
Mine came with the right plug attached. I think it's the generic ones that don't, and they are the ones that seem to have a short service life.
PostPosted: Sat Jul 27, 2013 10:42 pm Up
all the universal ones don't have a plug,so it's not a Plug & Play,you need to use your old plug,and match colors as the instructions say,but mostly need to match colors,as simple as that.
PostPosted: Sun Jul 28, 2013 4:10 am Up
Heard the universal ones are terrible, I would rather just get a second hand oem one to be honest
Mr-Tigger
PostPosted: Sun Jul 28, 2013 6:54 am Up
well seen as its the 97th solution to my fuelling/p0170 problem (yes it came back after 3 days) i just found a used oem one for 15squid and gonna see what happens,then if i get same fault least im not down a tonne. the non-oem i was looking at come with the plug ready to go,wasnt a universal thing,just a cheap brand
