Latest: Stu-mill
Overall: 17131
Online Now [258]:
Visitors: 257
Today: 85194
Total: 104770741
Forums › The Car › 206 Problems › 206 1.6 110 hdi. Fuel pump.
Johnpick
PostPosted: Sun Jul 28, 2013 3:56 pm Up
Hi guys another one for you.
The fuel lift pump doesn't seem to work. I've lifted the sea and there's no noise.
Which wires in the plug are for the pump?
I have 3 wires on the multiplying but 4connectors on socket on the top of the pump assy.
Is there a cut off switch anywhere?
Does it have a relay.
All the fuses in both boxes are ok.
Is it the wrong pump fitted?
A lot of questions sorry. I bought a Haynes manual but it doesn't cover the 1.6 110 hdi.
Thanks in advance
PostPosted: Sun Jul 28, 2013 3:58 pm Up
Easiest way to tell is disconnect a pipe at the engine and see if it pumps
Whats the fault with the car?
Johnpick
PostPosted: Sun Jul 28, 2013 3:59 pm Up
Doesn't pump. I've tried that. The car won't start at all
Johnpick
PostPosted: Sun Jul 28, 2013 4:00 pm Up
Sorry it starts briefly then cuts out as its starving of fuel
PostPosted: Sun Jul 28, 2013 4:09 pm Up
If it starts you know its working, as if im right the pump runs minues pressure and uses vacuum to the high pressure pump but i can be wrong! As my minds blank atm Laughing
Fault codes? Parameters? Any more info
Johnpick
PostPosted: Sun Jul 28, 2013 5:07 pm Up
No fault codes stored. As far as I'm aware the lift pump works on pressure rather than vacuum.
PostPosted: Sun Jul 28, 2013 11:16 pm Up
All HDi engines work on the High Fuel Pressure,so in your case you have 3 options:
1-The High Fuel Pressure sensor located on top of the fuel Pump is faulty.
2-The High Fuel Pressure Sensor located in the engine bay close to the (Common Rail Bump) is faulty.
3-The Common Rail Bump itself is faulty,as long your lift pump is working,so you might have inner failure when it get warm.
Johnpick
PostPosted: Mon Jul 29, 2013 5:25 am Up
Thanks ill have a look when I finish work
