Posted: Fri Aug 02, 2013 12:19 pm |
My 99 gti has started running on 3 cylinders. Replaced the coilpack but still doing it. Checked injectors all firing ok..... would crank or cam sensor cause this????
Any suggestions much appreciated... Thanks
Posted: Fri Aug 02, 2013 12:34 pm |
Checked the plugs too?
| Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling! | |
Posted: Fri Aug 02, 2013 2:08 pm |
crank sensor it wouldnt run and cam sensor would run lumpy rather than misfire
try plugs if you have not changed them
Posted: Sat Aug 03, 2013 1:10 am |
Thank... ill try the plugs today
Posted: Sat Aug 03, 2013 4:16 am |
When you take the old plugs out look for one that is a different colour to the rest. If it is plug related that one is your problem.
The above may not strictly be true that it is that plug but the problem is definitely related to that cylinder. It could be the plug (probably is) or it could be a burnt valve, worn rings or injector for that cylinder.
There are lots of plug colour charts on the web. Compare your plugs with the colour chart and you will have a good indication of how well your engine is running.
Posted: Sat Aug 03, 2013 4:58 am |
I have the same problem I changed the plugs and coil pack as I was told that was a common problem on pug's
so if anyone can help andybuff2000 and DrunknMonkey would be a great help
it runs fine for the first 10 minutes or so until the car gets warm and then runs lumpy please help thanks
