Posted: Sat Aug 03, 2013 2:08 am |
I am replacing the D bushes on the 206, only when I went to order them I was told they will either be 18 or 19mm.
Does anybody know off the top of their head what they will be on my 2000 1.6 xs?
Cheers
Posted: Sat Aug 03, 2013 4:37 am |
Check on servicebox to see which anti-roll bar is fitted. I've just looked at the TU5 and it lists 19mm and 20mm depending on the build code. Ideally needs to be checked using the VIN.
If you don't have servicebox, PM me your VIN and I'll check for you.
Posted: Sat Aug 03, 2013 8:54 am |
I managed to get hold of some vernier gauges in the end, mine is 19mm. Thanks anyway!
Posted: Sat Aug 03, 2013 9:04 am |
Mike_XS wrote: |
I managed to get hold of some vernier gauges in the end, mine is 19mm. Thanks anyway!  |
Where did you measure it?
Next to where bushes fit
Or under where bushes fit on the two flat bits from flat to flat?
Mine is 21.5 thought was 20.5 but just checked again
And flat to flat under bush is 17mm
So I'm none the wiser as to what bushes to get
Posted: Sat Aug 03, 2013 9:08 am |
wifes206 wrote: |
Mike_XS wrote: |
So I'm none the wiser as to what bushes to get |
Measured it 3 or 4 inches away from the bushes.
Posted: Sat Aug 03, 2013 9:12 am |
Mike_XS wrote: |
wifes206 wrote: |
Mike_XS wrote: |
Measured it 3 or 4 inches away from the bushes. |
Looks like I'll have to get the vin on here to get
some help
Posted: Sat Aug 03, 2013 9:14 am |
I was told by my local car parts dealer that they only do 18 or 19mm bushes. It's strange you are getting a .5mm measurement...
