Online Now [105]:
Visitors: 104
Today: 18907
Total: 138809380
Forums › The Car › 206 Problems › Arb size? So where do I measure it
wifes206
PostPosted: Sat Aug 03, 2013 8:27 am Up
Hi need new bushes but where do I measure arb
The diameter is 21.5 next to where bush sits
But under the bush has two flat bits
And from flat to flat it's 17mm
206 2.0hdi(04)
PostPosted: Sat Aug 03, 2013 11:29 am Up
Din't know you could get different bushes for different size ARB's.
Are you sure they're not all the same? (the bushes)
PostPosted: Sat Aug 03, 2013 11:37 am Up
This is what comes up for the 2.0 HDi. If you know your build code you can narrow it down, or you can even search for it using the VIN.
