Latest: Beduff1977
Overall: 17134
Online Now [632]:
Visitors: 631
Today: 90914
Total: 108233676
Forums › The Car › Request a how-to › Removing throttle Body Plastic Cover
Forum IndexRequest a how-to
Lizard2010
PostPosted: Sun Aug 04, 2013 4:20 am Reply with quote Up
My 206 GTI is idling erratically.
We want to clean the throttle Body.
But an unsure how to Remove throttle Body Plastic Cover
Could someone please advise asap.
In Advance
Owner of a 2001 Peugeot 206 GTI 2.0 16v
RichardEke
PostPosted: Sun Aug 04, 2013 4:49 am Reply with quote Up
Hello, found this in the how-to section.
www.206info.co.uk/Foru...46523.html
I did this the other day, 3 torx bolts and 15 mins cleaning.
Hopefully this is what you're after, but i may have mis understood, but i'm sure someone will point that out.
Regards, Richard.
Life would be easier with universal jointed arms and fingers sometimes
PostPosted: Sun Aug 04, 2013 6:29 am Reply with quote Up
On the side you'll see a hole maybe 10mm diameter. Put the screwdriver in there and it will find the screw for the jubilee clip clamping the cover onto the TB.
  Quick Reply
Username:
Message:
Quote the last message
