Latest: tebas93089
Overall: 17179
Online Now [129]:
Visitors: 128
Today: 30570
Total: 138291345
Forums › The Car › 206 Problems › Speedo not reading at all!
Brocagh2004
PostPosted: Tue Aug 06, 2013 11:34 am Up
Hey there, was wondering if anyone had any advice for me?
About a month ago the speedo on my 1.4 206 stopped working totally. Occasionally it flickers up to 10mph but that's about the height of it. It has two plugs in the back connecting it to the electrics.
I was wondering if I could just buy a cheap speedo and fit it myself without any other problems? Also, if I were to do this, would the new speedo read the correct mileage when I fit it?
Cheers
Hawkers
PostPosted: Tue Aug 06, 2013 12:08 pm Up
What year is the car?
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
Brocagh2004
PostPosted: Tue Aug 06, 2013 12:12 pm Up
It's a 1999 (I think), any ideas?
PostPosted: Tue Aug 06, 2013 12:29 pm Up
Check the state of the connections on the big multiplug behind the passenger side front bumper.
tommyb32
PostPosted: Tue Aug 06, 2013 12:33 pm Up
i could be wrong but isnt the mileage stored in the ecu? therefore if you where to replace the speedo it would have the correct mileage on it...
tommyb32
PostPosted: Tue Aug 06, 2013 12:38 pm Up
Just seen this post by someone also!
Also remember any replacement cluster MUST have a LOWER mileage on else you will trigger the anti clocking feature!
Brocagh2004
PostPosted: Tue Aug 06, 2013 12:39 pm Up
Yeah I thought the mileage would be stored on the ECU and so it wouldn't be a problem replacing the speedo, but can anyone confirm for sure that this is the case before I go ahead and but a new one? Thanks
PostPosted: Tue Aug 06, 2013 12:42 pm Up
Is the odometer clocking up the miles? Or is it both speedo and odometer that aren't working?
Brocagh2004
Thanks for that; is it easy enough to get to the big multiplug behind the passenger side front bumper?
Brocagh2004
PostPosted: Tue Aug 06, 2013 12:43 pm Up
The odometer is clocking up the miles, the only thing not working is the speedo.......everything else if sound
Jack123
PostPosted: Tue Aug 06, 2013 12:53 pm Up
I just changed mine, T Reg 1999, Got one from a 2000 car, You MUST get one with lower milage from a care before 2001, My mileage went from 100k down to 80k, so make sure you make a record of the old and new milage so you can always work out what the actual milage is.
The milage is stored in the unit, not the ECU, Atleast I don't think it is, when I changed mine the milage was 83000, and it didn't update to the cars higher, actual milage, so I'm pretty sure the milage is stored in the clocks.
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
Hawkers
PostPosted: Tue Aug 06, 2013 1:27 pm Up
If your car is multi-plexed, which is like after 2001 (don't know exact dates), then the car will take the mileage of the highest number to prevent clocking. If it's pre-plexed then it'll take the mileage of the actual speedo unit you put in it.
PostPosted: Tue Aug 06, 2013 1:38 pm Up
Not on a non plexed 206, they don't have anti clocking.
PostPosted: Tue Aug 06, 2013 1:39 pm Up
Not on a non plexed 206 it aint.
PostPosted: Tue Aug 06, 2013 1:44 pm Up
That suggests the speedo is at fault then. Otherwise the odometer wouldn't be working either if the problem was elsewhere.
