Latest: S2cgm
Overall: 17178
Online Now [90]:
Visitors: 89
Today: 35465
Total: 136680580
Forums › The Car › 206 Talk › Waterpump leak after cambelt and pump change
Davels
PostPosted: Sun May 15, 2011 6:05 am Up
I had my cambelt changed a month or so ago and at the time the guys noticed my waterpump had a slight leak. They were of the oppinion that it was lucky I was having the change so it was spotted.
Anyhow an unfortunate run of events saw me having to replace the tappets which involved cambelt removal and cam removal. When doing this the guys noticed the waterpump was leaking again. So they were straight off to get a new one under guarantee. New one fitted an looked ok but after a few mins started to leak again.
Turns out that the housing which the pump is fitted to is plastic and distorts over time, meaning I needed a new housing which pug have refined the design of and is now made of alloy not plastic.
Cost £60 and the part number from the invoice is [i'll add later as down in the car]
I thought I would mention this because if anyone is having the work done they may want to make sure their's is the new alloy type and not the older plastic type. If it wasn't for me needing everything off anyway I wouldn't have known until something failed or the leak worsened
PostPosted: Sun May 15, 2011 6:22 am Up
Thanks for that mate, I too have recently had my cambelt and water pump changed and have noticed a coolant leak on the underside of the engine so could well be the same issue you had
richy244
PostPosted: Thu Aug 15, 2013 11:48 am Up
Hi i had my waterpump changed just 2 months ago and now appears to be leaking.
This is the one i bought its for a 1999 1.1
www.ebay.co.uk/itm/Peu...0714518376
it just has a rubber O ring is this the same problem?
