Latest: Beduff1977
Overall: 17134
Online Now [119]:
Visitors: 118
Today: 216574
Total: 107618124
Forums › The Car › 206 Problems › Cable at front
Cable at front
Deano
PostPosted: Sun Aug 18, 2013 1:32 pm Up
Can some one plz tell me what cable behind grill is for much appreciated thanks
PostPosted: Sun Aug 18, 2013 2:08 pm Up
What cable? Top grille? Bottom?
Deano
PostPosted: Mon Aug 19, 2013 3:57 am Up
It comes up from left of rad has a little black thing on with like a button and another little wire next to it looks like it could only reach bonnet catch area ?
gazza82
PostPosted: Mon Aug 19, 2013 4:34 am Up
Brown connector?
PostPosted: Mon Aug 19, 2013 6:02 am Up
Alarm bonnet sensor.
Is car beeping when you lock it?
Deano
PostPosted: Tue Aug 20, 2013 4:50 am Up
No mate it's locking ok
gazza82
PostPosted: Tue Aug 20, 2013 5:22 am Up
Might only have immobiliser and not the optional alarm ...
Deano
PostPosted: Wed Aug 21, 2013 3:54 am Up
So does it just clip on so the bonnet shuts on little button
PostPosted: Wed Aug 21, 2013 6:45 am Up
138 GTi should have an alarm as standard. The alarm is operated by the tiny button on the catch.
