Online Now [557]:
Visitors: 556
Today: 81926
Total: 145980839
Forums › The Car › 206 Problems › can anybody tell me how to bleed the coolant on a 1.6hdi gti
vickys.hdi.gti
PostPosted: Wed Aug 14, 2013 2:33 pm Up
do you leave the top thin pipe off the radiator when filling? also is there a bleed valve any where?
Hdi power
PostPosted: Wed Aug 14, 2013 2:50 pm Up
No you use the two bleed nipples on the rear heater pipe and thermostat housing. The one on the housing is a allen key I think
vickys.hdi.gti
PostPosted: Wed Aug 14, 2013 2:57 pm Up
have you got any pictures of the where abouts?
Hdi power
PostPosted: Wed Aug 14, 2013 3:02 pm Up
Leave all pipes connected and fill system. There should be a bleed screw either on the thermostat or the pipe leading into the hearter matrix at the back of the engine bay. maybe both.
PostPosted: Wed Aug 14, 2013 3:04 pm Up
have a look at this thread,it might give you an idea on how to do it,cuz all coolant system are similar in one way or another.
www.206info.co.uk/Foru...56271.html
PostPosted: Wed Aug 14, 2013 4:39 pm Up
As me and addaz said, Timmons pics show the points. It's the same on all 206s/cars generally.
