Online Now [310]:
Visitors: 309
Today: 62560
Total: 106039648
Forums › The Car › 206 Problems › Removing steering wheel
peugeot7
PostPosted: Wed Aug 28, 2013 3:09 pm Up
We need to access the airbag ring, how do you remove the steering wheel cover (where the airbag is) and the steering wheel? Smile
Model is 2003 LX (53 plate)
PostPosted: Wed Aug 28, 2013 3:21 pm Up
well if you feel the steering wheel from the back,you will find a lock that is holding the airbag in place,to unclip this lock,you need to use a flat head screw driver,and insert it there,and push it down,and that will release it,but you have to be careful doing this,and don't forget to take battery off so that the airbag don't explode while u work there.
gazza82
PostPosted: Thu Aug 29, 2013 9:04 am Up
What model? One airbag clips on (multiplex), one it held on with screws ..
And after disconnecting the battery, leave the car for 20-30 mins to let the airbag system discharge ...
Place the airbag face up ... if it does accidentally fire, it won't launch itself into orbit via the garage roof! (It won't but I'd love to see one do that ... but not in my garage! Wink )
usher
PostPosted: Thu Aug 29, 2013 12:39 pm Up
Silly question but how do you set an air bag off out of the car
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Thu Aug 29, 2013 4:23 pm Up
Put voltage across the terminals.
Multimeter set on resistance or a PP3 battery out a smoke alarm will do it.
gazza82
PostPosted: Fri Aug 30, 2013 4:58 am Up
F***ing carefully! Laughing
