Latest: tbafonso
Overall: 17130
Online Now [293]:
Visitors: 292
Today: 114328
Total: 103039873
Forums › The Car › 206 Problems › Peugeot 206 brake light problem
vixytrixie
PostPosted: Wed Aug 28, 2013 3:15 pm Up
So having an issue with my brake lights, in that they arnt coming on at all!
I've had a look on the forum and have made sure the brake light switch under the glove box is in secure as I have had the problem with the lights staying on before but never having them completely not working.
It's a pretty beat up Peugeot so not looking to spend much on getting the car fixed so any help on whether it might need a new fuse, or something more serious would be great!
Any questions ill try n answer as new Ivan with my limited car knowledge!!
Cheers!
peugeot 206, sapphire blue, 2001.
PostPosted: Wed Aug 28, 2013 3:26 pm Up
does all the lights stay off,or the 3rd brake light is working?
vixytrixie
PostPosted: Wed Aug 28, 2013 3:30 pm Up
No brake lights come on, the bottom lights come on when I turn the head lights on bit absolutely no brake lights work at all..!?
PostPosted: Wed Aug 28, 2013 3:34 pm Up
well you have to check the earth strap,on the tail lights loom,as you might have a bad connection there.
vixytrixie
PostPosted: Wed Aug 28, 2013 3:45 pm Up
Oh ok, is this something that's easy to get too go have a look at?
Leegsi
PostPosted: Thu Aug 29, 2013 1:10 am Up
Have you unpluged the switch and shorted out the plug to see if it is the switch?
PostPosted: Thu Aug 29, 2013 1:53 am Up
Pretty sure there are two separate fuses on the brake lights, and one side feeds the third brake light but not sure which. If both fuses have blown at once then you could have a bad electrical problem.
Double check the connection to the switch to make sure it hasn't been dislodge by a passengers feet. Put a multimeter across the switch contacts and make sure that it is working properly.
vixytrixie
PostPosted: Thu Aug 29, 2013 4:08 am Up
Oh ok, are both fuse under the glove box, because I made sure that was all in place but read that there was one user the brake pedal?
PostPosted: Thu Aug 29, 2013 5:20 am Up
With your car being 2001, not sure if it's multi-plexed or pre-plexed, so here are links to both fuse lists.
Multi-plexed fuse list
Pre-plex fuse list
