Latest: tbafonso
Overall: 17130
Online Now [308]:
Visitors: 307
Today: 21372
Total: 104171370
Forums › The Car › 206 Problems › 2.0l hdi d-turbo gearbox oil filler location
woodmeist7
PostPosted: Thu Aug 29, 2013 4:59 am Up
hi just wondered if any could tell me where i put the gearbox oil in a 2.0l hdi d-turbo 2000 plate.
thanks
PostPosted: Thu Aug 29, 2013 7:08 am Up
Fill through the reverse light sensor till it dribbles out the level bung on the end of the gearbox.
The level bung is obvious, the rest are small bolts and it is about a 19mm on the end casing. It takes about 2 litres and doit on level ground!
woodmeist7
PostPosted: Thu Aug 29, 2013 9:15 am Up
cheers bud... that wasnt coming out at all. found the level checker bolt on the side behind the offside wheel hidden behind some plastic shielding. filled it through there until it started coming out constant. found a good link to this page tells u different places for different gearboxes.
www.justanswer.com/peu...-hole.html
