Online Now [232]:
Visitors: 231
Today: 41984
Total: 143032064
Forums › The Car › 206 Problems › horn not wokring?
horn not wokring?
wes180
PostPosted: Thu Aug 29, 2013 5:23 pm Up
right i have checked all the wires are conneted right but still doesnt work number 13 fuse is fine but when you press the horn there is a clicking noise in the engine fuse box so i think the wires behide the steering wheel are fine its the horn thats broke,what you guys think?
iainlovatt
PostPosted: Fri Aug 30, 2013 2:51 am Up
I would agree with you. Remove the connection and test for 12v on the loom when it is being pressed. You will then have your answer.
(My Garage)
PostPosted: Fri Aug 30, 2013 3:32 am Up
What He Said ,and also you can test the horn itself by giving it a direct 12 Volts,but since you got clicking sound when you press the steering wheel,then you are fine from the inside to the engine fuse box,which leaves you with the option of bad harness from fuse box to horn,or the horn itself.
iainlovatt
PostPosted: Fri Aug 30, 2013 3:36 am Up
I put a 180 Horn on my car few weeks ago, got the same, Clicking noise, Put the old one back and it worked fine! Smile Very Happy
(My Garage)
PostPosted: Fri Aug 30, 2013 3:47 pm Up
If its a dual tone, it could be a corroded connector on the horn. I took the wire off & had it as a single tone.
wes180
PostPosted: Sun Sep 01, 2013 10:14 am Up
it is a dual tone as its a gti 180 and i cant see any corroded wires at all,so am deffo thinking its the horn so got me self just a normal 206 horn to try and if that works i will just use that one as its ment be a proper pain in ass to remove the horn on a gti 180 bumper off job.
PostPosted: Sun Sep 01, 2013 10:39 am Up
It is a pain.....but try removing one wire at a time from the horn to see if at least part of it works.
wes180
PostPosted: Sun Sep 01, 2013 10:47 am Up
will give it a try cheers.
wes180
PostPosted: Mon Sep 02, 2013 7:35 am Up
there is just no way of gettin to the horn Sad
iainlovatt
PostPosted: Mon Sep 02, 2013 7:50 am Up
Yes there is remove the front bumper if you cant access it from underneath the car.
(My Garage)
wes180
PostPosted: Tue Sep 03, 2013 6:30 am Up
didnt really wanna remove front bumper as thats a major pain in the bum.
