Latest: lio94
Overall: 17181
Online Now [179]:
Visitors: 178
Today: 124804
Total: 140921372
Forums › The Car › 206 Problems › 206 Right Hand Side - Main Beam and Dip Beam not working? 05
jasw529
PostPosted: Sun Sep 08, 2013 2:57 pm Up
Hello,
Can anyone please help, my 206 (2005) main and dipped beam on the right hand side (drivers side) are not working?
I have checked the bulbs and fuses and they are both good??? The side light is ok on the right hand side and there is no warning lights/indicators, can anyone please help???
Many thanks for all your help. Hope to hear from you soon. Crying or Very sad
PostPosted: Sun Sep 08, 2013 5:14 pm Up
well take the bulbs out,and use a multimeter to check for voltage,if there is no voltage there,then you need to check the harness.
PostPosted: Mon Sep 09, 2013 1:18 am Up
Check the earth below the headlight.
PostPosted: Mon Sep 09, 2013 10:14 am Up
What He Said
Known 206 issue.
donnypaul81
PostPosted: Tue Sep 10, 2013 3:30 am Up
Had same problem give the connection a push up and down where the plug slots into the light unit if it works then pull out both plugs cut the wires and rejoin them with a connector block make sure u look how the wires join in to the plugs other wise you may burn out the loom lol
