Online Now [59]:
Visitors: 58
Today: 27837
Total: 105036221
Forums › The Car › 206 Problems › psi reset needed?
psi reset needed?
coolhas
PostPosted: Mon Sep 09, 2013 4:30 pm Up
hi i am planning on changing my throttle body on my peagout 206 1.4 auto for many reasons mainly because of fuel and low mpg problems
i have been told i need to reset my bsi is this true an necessary please advise
tRiCk
PostPosted: Mon Sep 09, 2013 4:35 pm Up
When a throttle body is replaced at Peugeot they will use diagnostic software to initialize the new part, it may or may not work correctly if not done, either way the car will let you know about it.
PostPosted: Mon Sep 09, 2013 5:22 pm Up
It will be fine.
Just disconnect battery (see apropriate procedure for mux car), leave for half an hour, re-connect and it's ready.
You should then reset the auto-adaptation after a few hundred miles once it's settled.
PostPosted: Mon Sep 09, 2013 9:40 pm Up
Obviously a diversion from your other post:-
www.206info.co.uk/Foru...56959.html
Are you certain that you have checked everything mentioned on that thread and the suggestion that we, not just me, have given you?
Fault finding by changing parts quickly gets expensive. Fault finding using second hand parts is cheaper but quickly gets confusing because you don't know the quality of the second hand part - you can add additional faults without knowing it or replace one fault with another . Added to that you are clearly relatively new to the 206 and system set up.
I fear you are heading for trouble, frustration or a lot of cost. If you are lucky or very knowledgeable you might get away with it but it will probably be luck. My fingers are crossed for you!
coolhas
PostPosted: Tue Sep 10, 2013 5:02 am Up
hi chhers whats the procedure for mux car
i found someone with the exact same problem and he said this worked while all else failed so i thought id give it a shot
