Posted: Tue Sep 10, 2013 5:08 am |
Hi all,what kit size should i fit to my 180 fitted with coilovers as they now catch the coil with th the wheels fitted back on...has anybody had this problem...cheers deano
Posted: Tue Sep 10, 2013 10:34 pm |
Just need some 5mm shims. Use existing bolts.
Posted: Wed Sep 11, 2013 3:06 am |
Cheers buddy, did use 3mm but they rubbed the coilover so fitted 5mm and they seam ok was a bit unsure about using the standard bolts but they thead in enough ok...cheers deano
