Online Now [1457]:
Visitors: 1456
Today: 87079
Total: 149162422
Forums › The Car › 206 Talk › 138 and 180 Gearbox Difference?
Forum Index › 206 Talk
Maybury180
PostPosted: Wed Sep 11, 2013 5:02 am Up
Hi guys,
Can anyone tell me if there is a difference in the gearboxes for the 138 and 180 as looks like my 180's gearbox might of had it so just wondered if there is a difference when i come to buy a replacement.
Thanks.
Adam
PostPosted: Wed Sep 11, 2013 5:32 am Up
I will check later but apart from ratios I dont think there is much difference.
If you want it rebuilt I can do it for £125 posted back to you plus parts
Maybury180
PostPosted: Wed Sep 11, 2013 5:47 am Up
Thanks Addaz if you can let me know the difference or i might look at having it rebuilt if there is any real difference.
PostPosted: Wed Sep 11, 2013 6:50 am Up
Pretty sure it is just the ratio's, I know the 180 run's a longer 1st gear than the 138 did. not sure if 5th or the final drive is different either.
Maybury180
PostPosted: Wed Sep 11, 2013 7:01 am Up
Thanks Lee just want to know if it will affect the cars performance, i assume if 1st is a shorter ratio it'll obviously get through 1st quicker but assume top end will be no different not that the car ever goes that quick anyway lol
DanT
PostPosted: Wed Sep 11, 2013 7:33 am Up
Ratios, and its been a long time since i looked at a 138 but i think they are linkage operated and the 180s are cable.
PostPosted: Wed Sep 11, 2013 7:39 am Up
The linkages can be swapped over quite easily.
DanT
PostPosted: Wed Sep 11, 2013 7:45 am Up
Many things can be swapped over easily on these cars but the op was asking the differences between them.
imjeeves
PostPosted: Wed Sep 11, 2013 7:52 am Up
The differences are the the first + second gear and the final drive. It has a taller first gear i.e you can go longer in first before changing to second. It has a larger final drive so that means all your gear ratios are lower than the gti to give it faster accelleration. Flip side is a lower maximum speed.
The linkages are also different due to the 180 being cable operated and the GTI being rods. It is not a simple swap unless you want to take your gearbox apart to change the linkage around??
I have just done all this so know whats involved
Maybury180
PostPosted: Wed Sep 11, 2013 8:37 am Up
Thanks, am i reading this right then that a 138 box would accelerate quicker due to the shorter ratio's but the top speed of my 180 would be reduced to that of the 138?
Thanks.
PostPosted: Wed Sep 11, 2013 8:50 am Up
No, the 180 box has a shorter final drive at 3.94 compared to the gti at 3.78. Meaning if you fitted a gti box it would have less acceleration but more top speed
Maybury180
PostPosted: Wed Sep 11, 2013 9:26 am Up
Thanks for clearing that up Addaz maybe its best to stick with the 180 box then.
Is it worth having mine reconditioned or buying a second hand 180 gearbox?
Thanks guys.
DanT
PostPosted: Wed Sep 11, 2013 9:44 am Up
Thanks guys.
Unless you're buying the second hand box from somewhere you know the history of it, i'd just get it reconditioned by a reputable place, otherwise the same thing could happen again.
Maybury180
PostPosted: Wed Sep 11, 2013 10:14 am Up
Thanks Dan, there is a couple of local gearbox specialists in the area, gonna check them both out and see what they think and what the cost is gonna be locally.
PostPosted: Wed Sep 11, 2013 10:31 am Up
Or there is me Laughing
I work for Peugeot main dealers and rebuild boxes regularly so the choice is yours
