Forums › The Car › 206 Problems › Fault code po130 |
Posted: Sat Oct 05, 2013 6:39 am |
[quote="gazza82"]bikesforme: did you check that head wasn't warped before you put it back? Might be stopping it properly seating and leaving a very slight gap which will cause water and possibly oil loss.
I think 206 engine uses stretch
Head was checked and was fine, has for the head bolts they were all replaced in a full top end kit. I have noticed a very slight leak in the exhaust on middle section, so i will reseal that when i get time.
I have also noticed a gushing water noise coming from passengers side top dash, the car runs brill apart from when you start it up first thing from cold. Engine shakes alittle like its only running on 3 , but is fine once you drive it.
I would not say i top the oil up much, mainly after i have done a lot of miles, most of my driving is very short distance 2-3 miles. I put about half cup of antifrezze mixture in every week to keep it topped up.
The dipstick and oil filler cap are just showing clean engine oil, the oil mist in the rad bottle is just about cleared up. so i think that was from when gasket failed before, but i cought it before it totally went, car has never over heated.
Car is coming up to 140k and she runs very well after her morning shakes, i also replaced fuel injectors with brand new peugeot ones, water pump and timing belt kit when head was done.
