Posted: Sun Sep 01, 2013 3:23 pm |
Hello,
I have recently purchased a 2003 Peugeot 206 1.4 HDI but only have the one key.
I'm looking at getting another key made but I was wondering, how do I find out if the car should have remote central locking?
I've heard when new they come with a remote key and a normal key (I could be wrong) and I only have the normal key.
Thanks!
Adam
Posted: Sun Sep 01, 2013 3:36 pm |
well I believe that you should have a remote one,but a VIN will confirm this
Posted: Sun Sep 01, 2013 3:37 pm |
What would I check the VIN against?
Thanks!
Posted: Sun Sep 01, 2013 3:56 pm |
Servicebox can tell you the spec your car would of left the factory with when you input your VIN.
| Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling! | |
Posted: Sun Sep 01, 2013 3:58 pm |
| Jack123 wrote: |
| Servicebox can tell you the spec your car would of left the factory with when you input your VIN. |
Posted: Sun Sep 01, 2013 4:03 pm |
It wants a password and I can't sign up.
Am I missing something?
Posted: Sun Sep 01, 2013 4:08 pm |
send me your VIN,and I will look it for you
Posted: Sun Sep 01, 2013 4:13 pm |
Done
Posted: Sun Sep 01, 2013 4:25 pm |
Looking at your avatar you're probably not far from me. If you need a transponder and remote programming let me know. You'll need to get the security code for the var first. if it's not on a card inside the glovebox, you can get it from the dealers.
I'll try not to mention the 4-1 ass kicking you got from Team GB yesterday
Posted: Sun Sep 01, 2013 4:27 pm |
| macca1411 wrote: |
I'll try not to mention the 4-1 ass kicking you got from Team GB yesterday  |
Haha thank you.
Yesterday shall not be spoken of, unfortunately I was there to witness that.
Posted: Sun Sep 01, 2013 4:32 pm |
Well you can have one,and since Macca is close to you,you will not find a better one to help you with what you want to do
Posted: Sun Sep 01, 2013 4:37 pm |
Perfect!
How much does it usually cost to get a new remote key made?
Posted: Mon Sep 02, 2013 9:25 am |
| Adamworthy wrote: |
Perfect!
How much does it usually cost to get a new remote key made? |
Between £57.74 & £67.64 for the remote depending on which of the 4 different multiplexed 206 remote fobs's is suitable for your car.
You used to get a free key blade cut to the car as well, not sure if they still provide this.
Then you need to add on the cost of coding the remote fob & also the immobiliser chip to the car.
NOTE: A Peugeot main dealer will require to see your photo id & proof of ownership for the car ( V5C registration document ) before they will sell / supply you a remote / key / security codes!
Posted: Fri Sep 13, 2013 3:44 am |
Hi I don't know if anyone can help I have the same question vin is vf32e8hxf42946264 thanks Lee
Posted: Fri Sep 13, 2013 3:57 am |
| pitbullpromos wrote: |
| Hi I don't know if anyone can help I have the same question vin is vf32e8hxf42946264 thanks Lee |
2003 SW 1.4 HDi
Supplied with 1 remote and one main key
Remote part number 6554YL £67.64
Blank key blade 9170JW £10.54 Pre cut blade 9926RF £15.82
